NX - 2nd Gen (2022-current)
Door light
Old Apr 20, 2024 | 12:25 PM
marvarro's Avatar
marvarro
4th Gear
Default Door light
Hi Dear Members,
I have an NX350 that has not equipped with lower door lights.
There is a single plastic cover there.
According to your informations, is there a cable behind?
It is possible to connect any light instrument there?
since today i was not brave enough to try removing the cover panel.
The model is NX Elegance Plus
thx. M.
Old Apr 20, 2024 | 01:09 PM
JasDmw's Avatar
JasDmw
The cable was there on mine. I think it depends on the model and the package you have. It's dead easy to remove and check. If it's not there, just snap the cover back into place.
Old Apr 20, 2024 | 01:23 PM
marvarro's Avatar
marvarro
4th Gear
Default Door Light
I was just asking because earlier I had a BMW.
There, the answer was very simple: “all models came with the same cable wiring loom.”
The connectors are all the same.
But you’re right. Tomorrow I will try to open the lid.
Old Apr 20, 2024 | 01:37 PM
IntrinoX's Avatar
IntrinoX
Most likely will have a wiring loom.
I got mine from lexusacc.com
Old Apr 20, 2024 | 01:44 PM
marvarro's Avatar
marvarro
4th Gear
Default Door Light
Thanks for the mental support!
I decided to remove the cover and I found you were right.
The connector is there, running to a blind jack.
It’s time to order the lamps!
Respect!
Old Apr 20, 2024 | 01:45 PM
IntrinoX's Avatar
IntrinoX
That's exactly what you need! Cheers!
Old Apr 20, 2024 | 07:21 PM
oreon333's Avatar
oreon333
I ordered my door lights from lexusacc as well, version 2 to be exact, and they look great, 3D looking and everything sharp , replaced the others that I have bought before, which had the blurry L and S letters.
Old May 16, 2024 | 02:01 PM
marvarro's Avatar
marvarro
4th Gear
Default Finally solved
I did ordered two different lights from the Aliexpress.
The first one arrived with wrong connectors, but it was easy to adjust the two pins in ought connect well. The overall cost was $8.71 That was with logo L in a circle.
I felt that has a better choice, so I was browsing more.
Later (still on Aliexpress) I’ve found the right one. The second one has multiple connectors for just $8.52 displays F Sport.
I think you can spare $90 by using this.
This was the first one.
And this is the second one.
Old May 16, 2024 | 04:39 PM
mookieson's Avatar
mookieson
What tool did you use to remove the plastic cover?
Old May 16, 2024 | 08:43 PM
Freds430's Avatar
Freds430
I have replaced six Lexus vehicles with Lexus puddle lights. Without fail I use a thin putty knife using the corner edge and placing it in the gap in one of the upper corners. Slight slight pressure and they have all popped out easily.
Old May 16, 2024 | 11:15 PM
oreon333's Avatar
oreon333
You can use whatever you have, something thin and flat, you can get trim removal tool if you like. The trick is to stick it on the right side, because the tabs on the light is only on one side, but it is pretty easy to pop those lights just stick the tool and pull the light out.
Old Dec 25, 2024 | 07:10 AM
IanG's Avatar
IanG
I checked my 2023 NX 250 (Canadian build) yesterday,I confirmed the door puddle light wiring was NOT installed on mine.
Merry Christmas
italia11
GX - 1st Gen (2003-2009)
Jan 10, 2024 01:13 PM
k3nju
UX Models (2019-present)
Oct 1, 2023 10:23 PM
paulwendy
GX - 2nd Gen (2010-2023)
Dec 23, 2017 09:54 AM
Amfraas
Nov 1, 2017 11:49 AM
furball
RX - 1st Gen (1999-2003)
Aug 10, 2009 11:08 AM
