NX - 2nd Gen (2022-current)
450H+ - infotainment screen do not display any data
Old Feb 7, 2024 | 10:34 AM
Yndigos's Avatar
Yndigos
1st Gear
Default 450H+ - infotainment screen do not display any data
Hello, since this morning, our NX ( 5 months old and less than 18.000 km ) show a black screen in place of infotainment data...
no more ac, no more radio, no more gps, no more Android auto...
We tried to restart by maintaining power buttons , but no luck.
Does anyone experienced this ?
Old Feb 7, 2024 | 11:13 AM
Droid13's Avatar
Droid13
Not totally. I've only ever had to reset my screen once, and that was because it went black as you describe, BUT... the difference was I could still see the HVAC controls at the bottom so I knew the screen was working, it just wasn't receiving proper data from the graphics system for the rest of the screen. A simple restart fixed it. In your case, it sounds more like hardware issue than a software glitch that a restart will fix. One thing to try before going back to the dealer, disconnect battery for a minute and reconnect and see what happens. If that doesn't help, then likely a hardware failure as opposed to a glitch.
The issue with electronics sometimes is that a simple restart doesn't fix all issues because sometimes its not a software glitch but a hardware glitch, and sometimes some hardware remains powered even thru on/off cycles or restarts. In those cases, completely removing power can sometimes help. I had a similar issue on a Subaru. Having issues that persisted over multiple times turning the car on and off, restarting the display screen, and even pulling some fuses I thought would help. Finally, disconnected battery, reconnected, Next start, everything worked perfectly.
Lhduran
Apr 6, 2026 03:14 PM
Fifteenkey
21
Jan 13, 2024 08:24 AM
Ken167
Nov 29, 2023 09:23 AM
b15
IS F (2008-2014)
12
Mar 27, 2022 06:53 AM
bluby_U
Nov 5, 2021 06:03 AM
