Dealer filled wrong oil
On the subject of oil changes - what really irks me is the 10k service interval for oil changes. My 1st gen NX had 16k miles without an oil change! It was a CPO and they said it was fine because of the synthetic oil used. The PO probably brought it in for 5k miles (no oil change) and "forgot" to have it serviced another 10k miles. Later I noticed that the dipstick had a bit of varnish on it - typical of oil used for too long. I used a bottle of auto-rx and it cleaned up that varnish (and the rest of the engine) and it was problem free until I sold it. I have heard there are wear problems on higher mileage toyota engines following extended intervals. I now do 5K changes on my own between dealership visits.
Changing grade of oil cautions:
My Canadian 2 cents (.015 USD) for what it's worth. Switching oil grades to thicker viscosities does not solve any engine woes, it doesn't last longer, it doesn't save on fuel costs (it reduces engine efficiency slightly because its thicker) it adds to running costs over time, and it more than likely will harm your engine over time.
The NX350h engine is the A25A-FXS which started showing up in Toyota's around 2020. It uses an electronic oil pump system that operates infinitely more accurate than older mechanical designs from the past. Now, the computer control for this pump is assuming you are putting in the specified oil (big sticker '0W-16' located under the hood states the oil grade required) or the exception of a slightly thicker grade (0w-20 as found in manual) to be used if 0W-16 is unavailable with the expectation that the next change you go back. The computer control can adjust the flow or volume of oil it sends throughout the engine with the assumption the right viscosity is in the engine. It's looking at operating temperatures, gas pedal position etc to send out enough oil. A thicker weight oil will deliver less oil to the engine which will over time slowly wear the lubricated parts more than expected and reduce engine life. Now, I'm sure were talking way down the road here, like after 100's of thousands of miles possibly. But in the meantime putting in thicker oil will add maintenance costs by lowering gas mileage slightly and have no other advantage. Toyota engine oils are made by Mobile One exclusively so no need to 'switch' to Mobile One you're already getting Toyota's specific formulation which is most likely better than off the shelf Mobil One.
I would however not do an oil change every 10,000 miles (16,000 kms) as per manual, that is something no expert mechanic will put their name behind currently unless you're leasing or plan to sell your car with less than 100,000 miles on it. Financially it's not worth it. I have made the choice to change mine every 5,000 miles or 6 months (8,000km's) because the oil and it's additives slowly decay with use and time and there is no substitute for clean oil to help preserve your engine. So I'm willing to eat this extra cost so that I can (hopefully) enjoy many years of engine health.
Explanation of engine oil change intervals for modern cars here:
Explanation of electronic oil pump can be found here at 6 minutes 30 seconds:
And for those of you who can't wait to pay more for even thinner oil viscosities used on newest Toyotas / Lexus vehicles; this video explains that the new 0w-8 is currently costing out at $20 a quart!!. at 15 minutes 45 seconds
I would like to mention the service director's words during the confrontation “ You’re like one of those 0.01% people who actually cares about the nitty gritty details to this extent”. I thought that’s exactly why they were ripping all the customers so far. For now, I don’t want to report this any further but I want to see them replace the 0W20 oil ASAP.
Coming to the dealership experience. I did my due diligence on having them fix the appointment and add on oil change as an extra at 5K mile service. I had to confirm thrice to make sure they are 1. Using the right oil 2. Doing the oil change 3. Pricing. Still they did this is absolutely disappointing.
I also just like your recommendation and coming by a recent discussion over the forum that some dealer overfilled the oil, I checked my oil level before going to the dealership to make sure where my oil level is and hopefully they are replacing the oil. Still beats me, they are doing things to their liking and thinking customers are like a cattle herd.
The first number is the cold viscosity, the second number is the hot viscosity. SoCal? You obviously should be thanking them for 0-20.
The computer does not “guess” at the expected oil pressure to actuate the vvt, it measures it with a sensor, hence the different country’s recommendation.
Yes, it is only for CAFE. Good on your service manager for trying to please you. Lexus/Toyota are tying themselves in knots switching recommendations trying to score green for the EPA.
Car cost is inversely proportional to car knowledge.
Yes it feels good to know 0W20 is not bad for the car after all but there is no way they can justify using 0W20 in my car without my consent provided the fact I was anticipating them to use 0W16.
Computer controlling electric oil pump in 350h is designed and calibrated for 0W-16, flow rates of oil will be less with a thicker oil and result in less oil getting to desired parts. Pressure rises with a thicker oil. Try to draw up a milkshake thru a straw compared to a soda.
I have never seen anyone verify an owner measurable mpg difference on public roads. Maybe try the prius forums?
Which is why I make an attempt to help people on this forum, some of which a don't know how to even read their manual and lookup information.
Peace to all. Enjoy you Lexus NXs
YMMV,
MidCow3
