NX - 2nd Gen (2022-current)
Trailer hitch.
Old May 10, 2023 | 11:38 AM
fst's Avatar
fst
5th Gear
Default Trailer hitch.
I just had installed by Lexus of Jacksonville a trailer hitch assembly with a rated towing capacity of 2,000 lbs. Also, at the time of purchase, I had the $160 towing capability accessory installed. Although I could have had the trailer hitch installed more cheaply elsewhere, I specifically wanted the installation done by a Lexus dealer as they were able to relocate the "power back door with kick sensor" and keep it operable. I have included a photo of the trailer hitch installation.
Old May 10, 2023 | 11:57 AM
mangust's Avatar
mangust
Thanks for posting the pic! The OEM hitch is pricey, but it sits higher than aftermarket options. The dealer also did a good job with cut-outs on the bumper.
Old May 10, 2023 | 12:20 PM
azieba's Avatar
azieba
Since you had a dealer install it, the receipt will contain the part numbers. Is it possible you could share the lexus part numbers? I believe someone had already posted the hitch part number but I don't think anyone posted the part number for the wiring kit (and any other parts related to the kick sensor).
Old May 10, 2023 | 12:37 PM
fst's Avatar
fst
5th Gear
1) Trailer hitch and kick sensor kit:
(a) PW960-78005 NX/H/PHV TOW HIT KIT
(b) 8910A-78010 SENSOR SET, KICK DOO
2) Trailer Hitch Harness for Trailer
5980 Trailer Hitch Harness 3.0
These are all the parts related references from the Invoices.
Old May 10, 2023 | 08:07 PM
azieba's Avatar
azieba
Thank you, I had hoped they would have a better part number for that harness that one could easily find on their parts site.
Old May 11, 2023 | 05:49 AM
fst's Avatar
fst
5th Gear
You could always call the Parts Dept. of the Lexus dealer nearest to you and ask them for the part number. It's worth a shot.
Old May 11, 2023 | 03:44 PM
SgtLip's Avatar
SgtLip
THANKS. What year and model vehicle do you have? Just curious if the PN's are all NX models or only a 350 or something else.
Is the hitch the square in the photo? Is it NOT centered on the rear of the vehicle?
Old May 11, 2023 | 03:47 PM
fst's Avatar
fst
5th Gear
2022 Lexus NX 350h model. The hitch is absolutely centered in the rear of the vehicle. Any other position would not be dangerous, but also crazy and not something the Lexus dealership would do.
Old May 11, 2023 | 03:55 PM
SgtLip's Avatar
SgtLip
Okay, thanks. Based on the photo and the tires, it looked off center. The open space between the hitch and the wiring looked to be the center. Appreciate the info.
Old May 17, 2023 | 01:37 PM
toyotaman7's Avatar
toyotaman7
Has anyone in Canada been able to get a Lexus original Hitch and wire installed?
Old May 17, 2023 | 06:59 PM
roadnx's Avatar
roadnx
10th Gear
I called my local dealer a few days ago.Their wiring kit was pretty expensive and very labor intensive. Even called out removing the front windshield wipers for some reason!I can't recall the exact price but thought is was over $300 just for the wire kit. I just installed the e trailer hitch and wiring. Around $400 total. It was scary taking the interior apart on a week old car, But it went pretty smoothly. The hitch instal was very easy. Probably took 6 hours, If I did it again more like 3 hours.
Old May 18, 2023 | 09:26 AM
jri's Avatar
jri
roadnx,
Which e-trailer wiring kit did you install? The only kit I've been able to find (that does not require splicing) is the Tekonsha 118868.
JR
Old May 18, 2023 | 02:18 PM
roadnx's Avatar
roadnx
10th Gear
They sent me the generic kit which required splicing. I saw a post somewhere that the plug and play kit did not. currently match our wiring.
Old Jun 26, 2023 | 07:14 PM
AtomicLexus's Avatar
AtomicLexus
Can you send me a scan of the hitch installation instructions. Unsure if I want to tackle the job without seeing what is involved? Or if anyone has a link online for it.
Old Jun 27, 2023 | 06:41 PM
SgtLip's Avatar
SgtLip
@fst It looks like they did NOT cut your plastic bumper. Can you tell me if they did? On another thread they shared a photo of one that was shredded. It looked like a 4 year old with scissors got a hold of it.
Thanks
