NX - 1st Gen (2015-2021)
Engine noise 2015 NX200t.
Old Oct 20, 2020 | 05:11 AM
NickyKB's Avatar
NickyKB
Default Engine noise 2015 NX200t.
Whenever I press the gas pedal, the engine's sound is so loud. Does someone have the same problem? And I feel it not smooth.
Old Oct 21, 2020 | 07:43 AM
olgzr's Avatar
olgzr
For the smoothness problem, are you using premium fuel? If not, then give it a try and see if it improves. For how loud the engine is, is the plastic engine cover installed? They help quiet down the engine somewhat. Also check the exhaust for loose connections or leaks.
Old Oct 21, 2020 | 02:08 PM
NickyKB's Avatar
NickyKB
often I use 91 and 95 fuel, the plastic all the time cover. Exhaust does not leak.
Old Oct 25, 2020 | 08:07 PM
heidihidin's Avatar
heidihidin
This is a 4 cylinder vehicle and will be louder than most. What are you comparing it to?
Old Oct 27, 2020 | 05:44 AM
NickyKB's Avatar
NickyKB
  • Have u try CX5 ? Its smoother and quite
Old Oct 27, 2020 | 03:58 PM
Lexuswiz's Avatar
Lexuswiz
I have been in and driven the current and prior generation CX-5 and the engine itself I find quieter but the road noise is more noticeable compared to the NX. USA CX-5's as far as I know are not turbocharged and the engine produces less power according to specs, so I do expect the NX engine to be louder.
Old Oct 28, 2020 | 10:32 AM
Redex's Avatar
Redex
I was going to make a thread, but today when I was doing errands every-time I pressed on the throttle I heard a slight whistle. It was only when I pressed on the throttle. It wasn't the turbo because I have drove turbo cars before, and the turbo makes a more profound noise than this whistle. I wanted to see if anybody else was experiencing this on their NX. Slight whistle from the engine when you're on the throttle, and only on the throttle.
Old Oct 28, 2020 | 04:10 PM
End1ess's Avatar
End1ess
yes, i heard the same too. Sounds like an electric car.
Didn't have this sound 2 years ago when I got the car, only start notice few months ago.
Old Oct 28, 2020 | 04:13 PM
Redex's Avatar
Redex
Does urs sound like that too? I have a 2017 NX200T and I don't know if I didn't hear it before or if it's the induction noise from the car.
Old Oct 29, 2020 | 07:23 AM
End1ess's Avatar
End1ess
I have a 2018 nx300 sound more like an EV car accelerate than a gas engine.
I wonder if it has anything to do with the cold weather or I only drive it once or twice a week.
JzRc
RC - 1st Gen (2015-present)
May 16, 2025 12:39 AM
Johnhav430
Oct 20, 2020 04:15 AM
Sunapollo
Hybrid Technology
Dec 6, 2016 12:13 AM
klex
Jul 8, 2007 03:11 PM
