NX - 1st Gen (2015-2021)
Acceleration Issue (2019 NX)
Old Jan 31, 2020 | 01:47 PM
cjessen's Avatar
cjessen
Default Acceleration Issue (2019 NX)
While at a complete stop I pressed the gas to accelerate and almost nothing happened. The car did begin to accelerate eventually but it was extremely slow. I released the gas and switch the car from Economy to Sport and that seemed to cure the issue. This has happened on several occasions now. Today it happened immediately after a hard brake (I live in Florida and no one knows how to drive here).
Has anyone had this problem? It also happened once as I was turning thru a busy intersection and I thought I was going to get T Boned.
Old Jan 31, 2020 | 08:21 PM
no1SomeGuy's Avatar
no1SomeGuy
Normal, especially in eco...throttle response is slowed, transmission doesn't downshift as eagerly to get you into the power band quickly AND there's a turbo to spool up before you get decent power.
I just drive in sport all the time, never bother with eco/normal....the fuel economy differences are negligable.
Old Jan 31, 2020 | 09:02 PM
swfla's Avatar
swfla
How long have you had the car? Has this ever happened before? Did you just fuel up?
Old Feb 1, 2020 | 03:02 PM
user 5976864's Avatar
user 5976864
Did you accidentally engage the snow mode button? I’ve used it a couple times and I would describe it as trying to accelerate from a stop in second gear.
Old Feb 2, 2020 | 11:56 AM
ross7777's Avatar
ross7777
There is a snow mode? I don’t have one in my 2019.
Old Feb 2, 2020 | 12:02 PM
user 5976864
I guess you’re right. I’ve always had one in all the Lexus’s I’ve ever had so assumed it was there.
Old Feb 2, 2020 | 12:29 PM
ross7777's Avatar
ross7777
Eco mode is essentially the same as snow mode.
Old Feb 2, 2020 | 03:35 PM
no1SomeGuy's Avatar
no1SomeGuy
No it's not.
Old Feb 2, 2020 | 06:45 PM
ross7777's Avatar
ross7777
Originally Posted by no1SomeGuy
No it's not.
It reduces throttle response which is pretty much what snow mode does to prevent wheel spin. It's not exactly the same but it's close enough.
Old Feb 3, 2020 | 04:45 PM
TechNut's Avatar
TechNut
Veteran: Navy
I disagree. It is my understanding that the snow mode was designed to “control” wheel spin. It makes use of anti-lock brakes if it detects spinning. It does not merely reduce throttle response, although that is clearly part of the eco mode programming.
Old Feb 3, 2020 | 05:14 PM
ross7777's Avatar
ross7777
Wheel spin is mitigated by traction control (brakes) in all modes. Snow mode reduces throttle response to prevent wheel spin.
Old Feb 3, 2020 | 05:41 PM
Grievous's Avatar
Grievous
Snow Mode will Reduce Throttle Response as well as put the transmission into Second Start if the vehicle does not feature a button specifically for enabling it. For example my 2020 GX does not have a snow button, but does have a button labeled [2nd Start] that will always start the car in second gear from a stop to reduce the chance of slip / wheel spin occurring.
Old Feb 4, 2020 | 04:21 AM
Lex2000TL's Avatar
Lex2000TL
Correct! In my old RX350 snow mode activated transmission start in second gear, to reduce torque. This was to minimize wheel spin due to low traction.
BuyingLX
LS - 5th Gen (2018-present)
Oct 12, 2019 07:14 PM
Kron1ck
IS F (2008-2014)
17
Apr 29, 2019 07:53 PM
Sobus666
RX - 4th Gen (2016-2022)
18
Oct 16, 2018 01:01 PM
1994 LS400
Mar 18, 2013 06:04 AM
kilo6_one
May 5, 2007 11:40 AM
