NX - 1st Gen (2015-2021)
Mr Dan
Old Nov 3, 2024 | 01:58 PM
danishny's Avatar
danishny
10th Gear
Default Mr Dan
My Lexus nx300 h after an accident damaging only side door ( front and back completely untouched ) is not starting it just starts the engine and than shuts off
it searched it’s due to pyro fuse .
can some plz help me to locate this fuse ? And how to replace it as its a mechanical switch .
google does t give me any thing on this hence posting here with knowledgeable and experienced sources.
regards and many thanks for reading and reply
Mt Dan Garry
Lexus 2017 nx300 h
Lexus 2017 nx300 h
Old Nov 3, 2024 | 02:22 PM
There is a fuse on the right hand side of the HV battery pack but not something you should mess with unless you have proper safety equipment and training. Maybe there is another high voltage fuse somewhere if so that's beyond my knowledge.
Old Nov 3, 2024 | 10:50 PM
danishny's Avatar
danishny
10th Gear
Thanks for response .
actually my available mechanic needs this info .
Old Nov 3, 2024 | 10:57 PM
Not sure about the latest version of Toyota's hybrid system but from what I know the engine won't start if the high voltage battery is not charged correctly or disconnected. My guess is there are a bunch of fault codes so the computer shuts off the engine to prevent you from driving the vehicle.
Old Nov 4, 2024 | 05:34 PM
n0v8or's Avatar
n0v8or
This document describes how to access the high voltage (~250 Volts DC) battery assembly:
https://www.lexus-tech.eu/HYBRID/HVD...X300h_AYZ1.pdf
04lx470
Jul 29, 2024 01:39 PM
jazzzman
May 1, 2023 10:01 AM
N1T3MARE
Maintenance
Jul 12, 2009 06:37 PM
jsyjordan
Aug 29, 2008 06:45 AM
