Suspension Problem?
Old Apr 15, 2008 | 06:28 PM
CLUB300's Avatar
CLUB300
Default Suspension Problem?
Hi I own a 2004 Lexus IS 300 (Sport Design) I lowered the car with Tein S springs. The car was fine for about 3 weeks and then all of the sudden i started feeling a shakyness coming from the right front tire, so i took the car for an allignment and was told that the car did not need one and it does not pull to either side. I put 4 new tires and still doing it. I took it to the dealer and they said that i need factory tires on it and it will stop. I think thats BS. Can anyone give me an idea. I feel that the car has lost some handleling and does not feel tight enough in sharp cornering. Still have factory 17" rims but not factory tires. ANY have an idea. All considerations will be appreciated. Can bad shocks cause this. My car only has 40K. The dealer fully inspected the car. looked for loose nuts, faulty bushings and motor mounts, but no problems. I also had the tires balanced. Im really worried at the fact that i cant fix this problem
Old Apr 15, 2008 | 06:59 PM
Apex84's Avatar
Apex84
Anytime you modify suspension you need an alignment. The person that told you otherwise is completely wrong. You def need to get an alignment ASAP especially if you drive a lot. If the this does not fix the problem check for lose nuts and bolts and have the tire balance checked.
Old Apr 15, 2008 | 07:10 PM
Sexy_Lexy's Avatar
Sexy_Lexy
Ditto Good Luck.
Old Apr 15, 2008 | 07:47 PM
PlatanoTLS's Avatar
PlatanoTLS
X1000 get an alignment...
Old Apr 16, 2008 | 04:15 PM
98LexLs's Avatar
98LexLs
I would check your upper ball joint and also the right inner tie rod.
Old Apr 16, 2008 | 05:17 PM
amorphous's Avatar
amorphous
I have had a lot of friends of mine install springs one their stock shocks and blown them out within a few weeks. Now my advice to you is to check every suspension compent and see if it is any bushings as 98lexls just said, or if it is the shock itself. The way I would check and see if it is the shock, take off the spring, then see if you can compress the shock with little effort. If you can compress the shock with little effort then the shock is blown. Everyone here is right about one thing though, with any drop you will need a alignment. Tires could affect the ride if recently replaced, different tires handle either worse or better then the stock tires. Good luck with finding an answer.
Old Apr 17, 2008 | 07:22 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
my car drove straight after the springs, when i got the spec sheet back after allignment, my toe was off horribly on both sides. camber and caster were surprisingly in spec. get the allignment
Old Apr 17, 2008 | 05:54 PM
mikez's Avatar
mikez
About how soon do I need to get alignment after I install the springs?
And do I need to get alignment if I install new rims + tires thats wider and bigger than the original?
Old Apr 24, 2008 | 10:38 AM
wowitztai's Avatar
wowitztai
yes i agress get an Alignment..i just got mine done and also camber was off still is but nothing they can do..but caster and toe is better now.
lexslexus
Dec 14, 2018 02:25 PM
brazos2
Suspension and Brakes
Oct 17, 2015 02:35 PM
hlu
RX - 3rd Gen (2010-2015)
Jun 19, 2014 06:24 AM
BradTank
May 24, 2013 11:25 AM
pylee257
Jun 19, 2007 11:06 AM
