Oil in the air filter
Old Nov 27, 2022 | 12:29 PM
Ksparks's Avatar
Ksparks
1st Gear
Default Oil in the air filter
The car is starting just fine however when gasing the car bogs down and putters. There is oil in the air filter. What would cause this and would this be why it's running this way?
Old Nov 27, 2022 | 12:40 PM
chuyrobles's Avatar
chuyrobles
Number one reason is a faulty PCV valve. Then worn piston rings, then clogged oil galleries. Put a new air filter to ensure that is causing the loss of power, then replace the PCV valve; most cost less than twenty bucks and should be replaced every 100K. Worn pistons would also cause blue smoke out the tail pipe. Clogged oil galleries is usually due to clogged oil filter due to not changing it on schedule.
unadad
LX - 3rd Gen (2008-2021)
Aug 21, 2018 07:24 AM
MnGs3xx
Sep 23, 2012 05:38 PM
Lyconian
Apr 4, 2011 08:54 AM
aznking
IS F (2008-2014)
Jul 15, 2010 07:51 AM
HowieNJ
RX - 1st Gen (1999-2003)
Jan 15, 2005 05:52 PM
