Tie Rods and shock ext.
Old Jun 6, 2022 | 06:13 PM
Junior76's Avatar
Junior76
5th Gear
Default Tie Rods and shock ext.
Hey guys. I’m having trouble connecting my tie rods, shocks, control arms on my 2007 Lexus IS250. I’ve tried starting from top to bottom. I’m not sure if the bearing on the cv axle popped off. How can I tell? And does anyone know a little cheat to help me out?
Old Jun 6, 2022 | 07:02 PM
What kind of trouble? Need more info.
Old Jun 6, 2022 | 08:41 PM
Junior76's Avatar
Junior76
5th Gear
I’ll be able to connect the upper and lower tie rods but nothing else. As in im pretty sure it’s the control arms n the shock. Or I can connect the two other thing but not tie rods and shock.
Old Jun 6, 2022 | 08:53 PM
So maybe the axle extended too far? I've had this happen was able to push it back in by fighting with it while rotating.
Old Jun 6, 2022 | 09:52 PM
chuyrobles's Avatar
chuyrobles
There is no upper or lower tie rod. There is a lower ball joint and one tie rod. No upper ball joint.
What parts were replaced?
Old Jun 7, 2022 | 07:18 PM
Junior76's Avatar
Junior76
5th Gear
oh well ill be trying that next week. at the moment i can't. I'll update you then. thank you
Old Jun 7, 2022 | 07:19 PM
Junior76's Avatar
Junior76
5th Gear
the differential was replaced
Old Jul 3, 2022 | 01:29 PM
Junior76's Avatar
Junior76
5th Gear
so I’m positive the axle is pushed in all the way. I can see it on the diff. Part
cjinthesky
May 28, 2021 07:08 AM
GUNRU-GS4
Suspension and Brakes
30
Jun 3, 2016 06:09 AM
questnyc
May 16, 2009 12:09 AM
e-man
16
Apr 28, 2006 07:30 PM
