2014 IS350 Cranks & Dies
Greetings! 2014 IS350 will crank, sometimes turn over, then dies. I’ve ran the OBDII but she’s not throwing any codes. Additionally all power things function correctly and battery checks fine with multimeter. When I turn the power to ON and lay under the car near the gas tank I hear humming which leads me to believe the fuel pump is working (unless I’m hearing something else). I’m think fuel pump relay, filter, or fuel pressure sensor... thoughts?
Get the battery load tested volt meter is not a valid way to check battery health.
NYC ES3
09-14-08 02:32 AM
