Mini floor jack? just for tire rotation
I just need to be able to lift a corner and fit a jack stand underneath to either swap wheels, or do a brake job. Plus would like to bring this to track days, so portability is a plus.
I only have an IS350, so I figure something like this would work?
https://www.amazon.com/BIG-RED-T820014S-Hydraulic-Carrying/dp/B07ZK29RRF/ref=sr_1_3?crid=16QWKISP65K05&dchild=1&keywords=torin+big+red+jack&qid=1597762133&sprefix=torin+%2Caps%2C639&sr=8-3
Side bonus:
My roommate has a 4runner, and I guess this wouldnt work? He was explaining to me that he needs to be able to lift an axle on each corner, and thats something Im not familiar with. Would this get the job done for swapping wheels?
Thanks ClubLexus
Side bonus:
Thanks ClubLexus
You should consider this one : https://www.harborfreight.com/15-ton...ack-64545.html
They usually have them on special for $59.99.
if you are having problems getting the jack to slide underneath the car, place a couple 2x4's in position where the front / rear tires can drive up on them. This will give you a little more clearance. It will be a tall order to find a jack that works on both your IS and a 4 runner.
Tact
19
Feb 12, 2024 12:37 PM
mckellyb
RX - 4th Gen (2016-2022)
16
Mar 9, 2018 05:27 PM
