Where can I buy...?
Old Feb 14, 2011 | 05:01 AM
K4GIXXER6's Avatar
K4GIXXER6
Default Where can I buy...?
I've checked at every local autoparts store and googled online for one but where the heck can I find a 10 inch 3-point Phillips screwdriver? I need to aim my headlight up a little bit and the stealerships keep telling me it can't be done when clearly it can. Thanks in advance.
Old Feb 14, 2011 | 05:04 AM
Luxotic's Avatar
Luxotic
try snap-on or matco or mac tools .... did you try looking online
Old Feb 14, 2011 | 05:11 AM
K4GIXXER6's Avatar
K4GIXXER6
Yes I have.
Old Feb 14, 2011 | 05:28 AM
gridlock13's Avatar
gridlock13
home depot or lowes?
Old Feb 14, 2011 | 05:49 AM
IXI187IXI's Avatar
IXI187IXI
ive never seen a 3 point phillips head. im sure its called something different if its a 3 point, maybe thats why you cant find it
Old Feb 14, 2011 | 06:40 AM
Lex Luga's Avatar
Lex Luga
I agree.. its impossible to find even online.. i jus adjusted it with a 10inch #2 philips head.. adjusted the beams three times.. the beams r at a perfect level atm but if i adjust anymore i might strip em for good... i need to buy this just like OP
Old Feb 14, 2011 | 06:47 AM
BurgBoxstr's Avatar
BurgBoxstr
3 point phillips head Never heard of such a thing...
In my '07 it was a std phillips head driver #2 IIRC. Have you searched the forum for details as it's been covered a number of times?
See this thread from about 3 years ago and my posts 21, 28, and 30 with pictures of the correct location. Also, the car must be running (for the AFS and auto level to initialize) before adjusting.
Old Feb 14, 2011 | 02:10 PM
K4GIXXER6's Avatar
K4GIXXER6
Thanks everyone for your replies. I've never seen a 3-point Phillips myself but I was just going off the video in the DIY sticky thread about adjusting our headlights, in the video he says to use a 10 inch 3-point Phillips. I guess the search continues..
Old Feb 16, 2011 | 05:55 AM
BurgBoxstr's Avatar
BurgBoxstr
I think they mis-spoke or you slurred your hearing
What was likely [meant to be?] said was.... a 10 inch, [number] 3, pointed phillips...
emPHAsis on wrong sylLAbles and punctuation will kill ya every time
If you're talking about this thread from the DIY sticky, the video is no longer there, that I can see. Ironically, here is post #13 from that thread espousing a similar issue to yours but not being able to find a 10 inch, number 3 phillips...
Originally Posted by Lex Luga
here is the thing...I cant find a 10 Inch #3 philips head screwdriver anywhere (autozone, home depot). Where can i find one?
I used a #2 10 inch and it worked but im scared i might mess up the screw in the future and not be able to adjust it anymore
Anyhow, use the posts I noted in thread linked in my post 7 above. In those I show you exactly where to adjust and a picture of the #2 phillips screwdriver I modified to work. FYI, a US bill is 6.14" long - same size regardless of denomination .
Old Feb 16, 2011 | 09:36 AM
Lex Luga's Avatar
Lex Luga
Like I posted in #6 of this thread. I ended up using a 10" #2 philips but i think the head will strip the screw, I can already feel the screw not catching the screwdriver securely, I have to apply extra pressure and go extra slow so it doesnt strip it more.
p00rbob
Mar 3, 2013 10:39 PM
williamb82
13
Oct 1, 2010 02:29 PM
DRFT103
Apr 28, 2010 10:32 AM
archangels
RX - 1st Gen (1999-2003)
May 23, 2008 03:29 PM
