Please help ((EGR valve excessive flow))
Old Mar 11, 2011 | 09:53 PM
KevinES300's Avatar
KevinES300
Originally Posted by GS4_Fiend
You would need to check out the EGR's VSV. That's the valve that provides vacuum to the EGR to make it operate.
Toyota doesn't use DPFE on their EGR system.
Can u please tell me where is the location of the VSV.
Old Mar 11, 2011 | 09:57 PM
KevinES300's Avatar
KevinES300
Originally Posted by mitsuguy
sorry, its not called DPFE then, is the vapor pressure sensor... its two different names for what ends up being the same thing - its the thing that measures egr flow... one is a pressure sensor, the other is differential pressure sensor...
The error cods for EVAP sensor is different (P0446, P0442, P0440) and i am not having any of those
but you might be right because when i top up mt fuel level the light goes OFF and when the level drops to quarter the CEL pops back ON
do you recommend getting one from a junk yard?
Old Mar 14, 2011 | 01:18 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
I really wish I had access to Mitchell like I used to at my shop... but, I did find this for you...
It is a PDF with the troubleshooting step by step flow chart...
It would seem that Lexus, at least on the mid-late 90's ES300's used a temperature sensor to determine EGR flow...
File Type: pdf
dvdchance
Feb 26, 2016 07:05 PM
Eric00GS3
Jan 17, 2008 10:37 AM
vstolyarov
Apr 5, 2007 07:06 PM
prjctSC300
Maintenance
Oct 13, 2005 11:33 PM
