fish tailing
Old Dec 17, 2009 | 09:37 PM
Lexs400's Avatar
Lexs400
Default fish tailing
my 90 LS has developed a weird phenomena.
at highway speeds the rear literally feels that it's going to give out when changing lanes. kind of like a boat. i believe it's called fishtailing...
what bushing/part would i need to replace to correct this ?
thanks.
Old Dec 18, 2009 | 01:22 AM
Hayk's Avatar
Hayk
How are your tires doing? Have you done an alignment check?
Old Dec 18, 2009 | 08:12 AM
Lexs400's Avatar
Lexs400
tires and alignment are goood.
Old Dec 18, 2009 | 03:04 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
alignment is not good...
guarantee it... it might be sitting OK while on an alignment rack, but my bet is that you have some worn bushings somewhere... if any suspension bushing is worn, then the alignment is completely inaccurate...
so, have a good tech take a peek at the bushings, front and rear... have the bad ones replaced, and have the car aligned properly...
Old Dec 18, 2009 | 06:29 PM
VVT-i's Avatar
VVT-i
He's right, check the rear lower control arm bushing. The bushings located on the very bottom of the rear knuckle. You can buy the bushing for $80.00/pair.
Old Oct 30, 2010 | 09:39 AM
Lexs400's Avatar
Lexs400
have the rear control arms replaced. issue exists. Loud thump noise when going over bumps or through minor pot holes etc. noise is coming from rear. Struts are new. control arms new.
any ideas ? had alignment checked again came out ok.
Old Nov 5, 2010 | 01:55 PM
RA40's Avatar
RA40
Super Moderator
Rear strut bar bushings. Although if you have any worn bushings, a good tech will see them and tell you during the process. Getting a good alignment is near impossible. How are the tires wearing? Cupping?
Old Jan 27, 2011 | 08:36 PM
svlexus's Avatar
svlexus
We cant diagnose stuff over internet. Get an oil change and ask them to look at it. Im guessing the sway bar link is bad or broken.
AVIAT0R
Dec 12, 2019 09:35 AM
blk200t
Suspension and Brakes
Jun 20, 2019 07:28 AM
PhantomV
Oct 13, 2014 11:43 AM
speed6
Dec 13, 2008 02:45 PM
BA_GS400
Feb 4, 2008 09:52 PM
