93 sc300 window regulator
Old Mar 11, 2009 | 11:55 AM
WIZARDGUY's Avatar
WIZARDGUY
Default 93 sc300 window regulator
New to the forum, good to be here. I just bought a perfect 1993 SC300 without a scratch. The only issue is the pass side window will not operate. The motor works but you can move the glass up and down by hand. How do you change the regulator? i have the panel off (I own a audio/video/perf shop) but it looks like a bear to change. Any tips?
Old Mar 15, 2009 | 08:13 PM
vwynn's Avatar
vwynn
simple to change. if you have the panell of.. roll the window so its mid way, remove that one center plate, remove bolt that holds regulator, remove the 2 nuts that hold the bracket to the window, move window all the way up and tape it, and jiggle that regulator out and replace. sry if it sounds vague.
Old Mar 16, 2009 | 12:05 AM
TheMole's Avatar
TheMole
Here you go:
https://www.clublexus.com/forums/sho...d.php?t=341373
https://www.clublexus.com/forums/sc-1st-gen-1992-2000/95720-window-regulator-fix-for-sc-models.html
Eddycanuck
Feb 19, 2013 11:59 PM
jaseinatl
Apr 11, 2010 02:42 PM
RalAegidius
Dec 15, 2004 06:33 PM
