O2 sensor
I told the Check Engine Code # to the garage, and they still are going to charge a diagnosis fee because "our inspection is very thorough and takes an hour, compared to the 20 second check that AutoZone did".
Are they fleecing me, or is that legitimate? Should I find a garage that will just replace the part based on the code?
Here's the deal, it's a cover your *** situation... On the internet here, I am free to make suggestions based on a code and symptoms, but in the real world, guessing (even an educated guess) just doesn't cut it...
if they replace that part, and the light comes back, it leaves them open to complaint "well, you replaced this, but it didn't fix it, the light is back" Which they are trying to avoid obviously... whereas if they do the diagnostic (which will be more intense than just pulling a code - they'll probably test the circuit and such), they'll be sure that what they are going to do will fix the issue... chances are if you want them to just replace the part, they'll have you sign something saying that you understand it may/may not take care of the problem...
here's the scenario with your code which is o2 sensor heater circuit, iirc... there are a couple things that cause that - faulty sensor, bad wiring, bad ECM... if they guess and replace the o2 sensor, and the problem still exists, trying to appease a pissed off customer could mean replacing the ECM, which is not a cheap task... so, they err on the side of caution...
keep all of this in mind.... obviously replacing the o2 sensor is the cheapest (short of splicing a frayed wire), and is where I would start if I was guessing at a fix, it is the most common...
But, things I do question people about, specifically:
alignments (most people think an alignment will fix all pulling and shaking, where it might be a tire issue)
engine parts replacement (obvious, as mentioned above)
coolant flush (probably not going to fix an overheating car)
transmission flush/service (if the trans is slipping, its a good chance this will not fix the issue unless its severely low)
There are others I'm sure, I just can't think of...
I will tell you this, somewhat recently, I did ask a lady why she wanted an oil change - I was asking her what type of oil she wanted, asked what type of driving she did, and she responded with, oh, I've just never changed the oil in this truck... it was a 4.7L Toyota Tundra, 2002 model... Assuming she just bought it, I asked how long she had had the truck, to which I was told, "since new" Meaning, she had 5 years and 42000 miles on the original oil.... there was only about 3 quarts in the crank case, and was starting to smoke...
what an idiot...
truth is, as a shop service manager, it's very hard to trust customers, so you get as much information as possible - customers lie, they leave out important information all the time - which I don't understand, it's like they feel guilty about something and don't want us to find out, where all we are trying to do is help...
what an idiot...
JimA
basis for that suggestion - if you know 5000 is the upper limit, but know you should do it as early as every 3000 miles, it'll give you a good sized window to do it at your convenience...
