air conditioning problem
Scott
Thats really not that expensive (for a retail shop) though when you consider they have to evac and recharge the system... the rest of it is getting to the expansion valve... 5 hours shop time I would imagine...
but i have basic mechanic skills
but i was curious if this would be a common diy er
now, if you can get ahold of that stuff, its all pretty basic stuff...
It was charged with freon and worked for one day then died.
No 12 V DC to the Compressor. I am going to check that Mag, CLT Relay.
Thanks.
Looked over troubleshooting charts from several online sources and after taking a lot of readings with the volt-ohmmeter on fuses, switches, resistors and relays, discovered a bad commutator on the fan motor was probably the cause, having stopped on a bad segment. Reading a little further I found one online tech on a Dodge site who recommended slapping the motor (mounted behind the glove compartment with the shaft looking up) on the bottom with an open palm to restore operation . . . then a flurry of responses saying not to try it for fear of damaging the motor further.
Well, that concerned me, and after I put the part on order (RockAuto.com), I drove over to my neighborhood garage to see if the guys would install it for me. It's a simple fix, requiring removal of only six screws to drop the blower assembly, slip the new one in, plug it in, and make up all the screws again. I'd do it myself, except if I manage to wedge my bulk between the front seat and the door frame, it's going to take the jaws of life to get me out. I've had experience in this and it's a little embarrassing to have friends come over to extricate me from my work.
While talking to the mechanic and making a deal for his installation, he asked if I'd slapped the fan motor yet. I said no, with so many cautions against it, I was a little reluctant to try. He said he'd had a Caravan come in several months ago and the brute force treatment worked. I had nothing really to lose at this point so he crawled in, smacked the fan motor, and turns the key. The blower hummed to life and has worked fine all week. In our 100°+ temperatures it's been a lifesaver. Funny how sometimes the crude fix actually works . . .
The new blower arrived this afternoon and I'll take it over tomorrow morning and let him install it - it's not a good idea to gamble on that armature stopping on that bad commutator segment again, risking some real damage to the wiring and connections. Meanwhile this evening we continue to play commutator roulette. Very carefully.
____________________________
Update: Replacement complete, $60 labor, $43 parts (including shipping). After a couple of months listening to that old blower roar, I spent a good deal of my Sunday driving trying to turn the blower to a higher speed. It was cooling just fine (you didn't want to sit directly in the blast of air from the AC for fear of frostbite), especially on a 102° day, but the system now operates as quietly as that of the Lexus.
