Rear Diff. GS400
Old Jul 8, 2007 | 08:57 PM
  #31
Cadd's Avatar
Cadd
Update: I changed the rear diff fluid today. Used Mobil1 75W-90. So freaking thick!
Oil smelled like rotten egg, but not as bad as what others said about Redline oil.
Drain: No idea
Fill: 1 quart 24 ounces
Drain bolt was easy to open
Fill bolt was a PITA. I just wouldn't move (of course I opened the fill bolt first).
Drain bolt also has a magnet. Lots of metal scraps on mine!
Hopefully this will last me a good few years before I have to drain & fill again.
Old Jul 22, 2007 | 07:33 PM
  #32
vwynn's Avatar
vwynn
ok so cadd has answered my question that was in my head.
heh What does diff oil smell like. =]
ok anyways feel anything different in the car?
Old Aug 13, 2007 | 08:57 AM
  #33
eg92b16a2's Avatar
eg92b16a2
Is amsoil 75w90 good to use compared to redline?
Old Aug 13, 2007 | 09:48 AM
  #34
GSteg's Avatar
GSteg
Honestly, both are great differential oil. I bet I can put either one in your car and you wouldn't be able to tell a difference
Both of them will exceed your daily driver's need. Just pick whichever one you prefer.
Old Aug 20, 2007 | 07:44 PM
  #35
eg92b16a2's Avatar
eg92b16a2
Thanks for the info!!
Did it this weekend and it went pretty well.
Will it hurt if I used too much fluid?
I ended up with a 1/4 of a bottle left. But I also poured some in with the drain bolt off to make sure everything came out.
Old Nov 20, 2007 | 02:24 PM
  #36
Cadd's Avatar
Cadd
So let me ask this again....one drain & fill gets almost all the fluid out? So no need to do more than one drain & fill, right?
I lost my owner's manual. What is the recommended change interval?
Old Nov 20, 2007 | 03:15 PM
  #37
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
correct, just one drain and fill gets 99% of the fluid out...
no recommended interval... it just says inspect every 15k
Old Nov 20, 2007 | 04:55 PM
  #38
MGS4's Avatar
MGS4
I use Redline 75W90. was thinking about using lightweight 75W80 but was too chicken to do it.
acegunter
Sep 1, 2021 05:10 PM
wvuguy
RX - 1st Gen (1999-2003)
34
Dec 12, 2017 04:22 AM
Rocknrose
Jun 28, 2016 04:55 AM
Chenzo26
Performance
51
Dec 22, 2011 05:49 AM
klein4896
Maintenance
Mar 18, 2009 09:26 AM
