94 sc engine cuts off
Old Nov 27, 2006 | 11:27 AM
94scfl's Avatar
94scfl
Default 94 sc engine cuts off
I have a beautiful 94 sc400 with 76000 miles on it . It is a 2 owner car( adult drivers ) always maintained . The problem is it will cut off while driving or at a stop, everything shuts off including interior lights .My mechanic thought it was the starter , we replaced it , the car still is cutting off ! Has anyone else had this happen ? Is it electrical? a chip?, i have know idea other than this the car is in perfect shape! Thanks for any ideas or suggestions m moore jacksonville fla
Old Nov 29, 2006 | 07:37 PM
salimshah's Avatar
salimshah
25 Year Member
Red face
starter would have been the last item on my check list ... since you have no starting problems.
When it shuts off, do any of the instrument warning lights come on? From your post it seems your car suffers from electrical outage --> no ignition --> car dead.
I would check the fuses, wires comming into the fuse boxes etc.
Also check the car history ... flooding etc in the past etc. Give previous owners a call to see narrow down to an instance since the problem cropped up.
Intermittant problems are hard to catch and fix. imho I dont have too much trust in your mechanic, since you did not have starting problems
Salim
Old Nov 29, 2006 | 10:54 PM
PERRYinLA's Avatar
PERRYinLA
Default worth a try.....
Hopefully it is as simple as a faulty battery ground strap.
Might not be, though, but be sure to check it, to eliminate that possibility.
Old Nov 30, 2006 | 12:02 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
It is USUALLY the fuel pump ECU or fuel filter on the Sc's.
Old Nov 30, 2006 | 08:36 AM
np20412's Avatar
np20412
If this is the case, it tends to sputter around 200-300 rpms right before it shuts off, but this is certainly a possibility.
Old Dec 20, 2006 | 02:19 PM
no2faber's Avatar
no2faber
maybe see if the mechanic can test the alternator as well. if it's not charging your battery properly you could be losing power when your driving or at a stop.
robbruce
Feb 18, 2018 10:39 AM
GS400AZ
Apr 14, 2015 08:02 PM
johnyTran
Dec 13, 2012 12:56 PM
mercpu66
Jun 19, 2010 03:20 AM
bonez28
Dec 6, 2009 12:42 AM
