Replaced the Starter Relay Assembly but still no power to car.
I replaced the Starter Relay Assembly (28300-21020) but still no power to car.
Last night the relay blew and I replaced it today. I replaced it with the battery still connected (oops), so then I disconnected the battery for 20 mins, then reconnected it and still no power at all (no interior lights, dash, etc.. NONE).. The battery is fine. I even tried to jump it and still no power..
What do I check/do next?
I believe the starter itself should not prevent you from having interior lights, the starter is for starting the engine so if you turn the switch on acc or ign then you should get lights. since you have been working with the starter, i suspect that it is to do with key/push start wiring. an easy way to check is to use a multimeter and see if you have power going to the starter
