Lowered IS300 help
Old Apr 28, 2006 | 10:11 PM
5gears-IS's Avatar
5gears-IS
Great Deal Guru
Default Lowered IS300 help
Guys,
I lowered my IS300 with Intrax springs, mounted new tires and had an alignment done on it.'
My wife was following home and she claims that my rear tires look like they are on an angle.
When I parked home I checked it out and they do look like they have positive camber........
I took it back to the shop that performed the alignment and he said they had no problem with my car and everything should be ok. I am not satisfied with how the car looks because the front tires look straight and the rears dont. My question is, has anyone experienced this when lowering your IS and are camber kits available for the IS??? WHat do you guys recommend do?
Old Apr 28, 2006 | 10:29 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Negative camber is a characteristic of lowering the IS' double wishbone suspension. Unfortunately there are no camber ktis out there to correct this. All the GS and IS guys on lowered suspensions experience this either on coilovers or springs. It's the geometry of the suspension that causes this. The lower you go, the more negative camber you have. Even more so with a load in the back.
What you are seeing is negative camber. Here's a little diagram explaning this on Discount Tire's website.
Old Apr 29, 2006 | 12:03 PM
5gears-IS's Avatar
5gears-IS
Great Deal Guru
Default Great info...
I guess I will live with it. Thanks!
Old Apr 29, 2006 | 03:06 PM
meZoom!'s Avatar
meZoom!
Super Moderator
the good news is, your negative camber (when it is even) can yield better handling and is safer than positive camber. so start saving up for tire money!
Old May 1, 2006 | 09:14 AM
b1gredek's Avatar
b1gredek
my advice,,,, every so often check out the inner of the tires,,,, when they start wearing out too much,,,,, flip the tires,,,,, this way you can get many many more miles out of your tires.....
Toxicxk23
Dec 29, 2012 09:09 PM
murder
Suspension and Brakes
Jun 11, 2011 07:16 PM
imadesign
Feb 25, 2011 04:40 AM
Johnny D
GS - 1st Gen (1993-1997)
Jul 27, 2007 10:48 AM
raul
IS - 1st Gen (2001-2005)
Nov 8, 2001 04:00 PM
