injector cleaner
Old Aug 8, 2005 | 07:14 PM
sexilexi's Avatar
sexilexi
Default injector cleaner
Which injector cleaner products do ya'll recommend running through the gas every now and then?
Old Aug 8, 2005 | 07:30 PM
koolaidman's Avatar
koolaidman
gm top engine clean
Old Aug 8, 2005 | 07:43 PM
HarrierAWD's Avatar
HarrierAWD
Injector cleaner is not necessary with modern engines and fresh gasoline (hard to find stale gas nowadays with the tight supply.) Use any brand name gasoline and your engine will do fine. I never used injector cleaner in my 2002 RX300 and never a problem. I even buy gas from 7Eleven.
The GM stuff is not really an injector cleaner. It is poured into cylinders directly (through spark plug holes) to remove carbon deposit on top of the pistons - a common problem with GM cars. You leave it in overnight, put a towel on top of the engine and crank it to get all the gunk out. I played with it once and it ain't pretty.
Old Aug 8, 2005 | 08:05 PM
lexusk8's Avatar
lexusk8
From my experience, I've noticed a mileage difference when using an injector cleaner product like Chevron w/ Techron Concentrate. I usually fill it into the tank 1-2 times a year, and it provides a 1-2 MPG improvement every time.
Old Aug 8, 2005 | 08:14 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
I would agree with the cheveron products... I have used this stuff before even in my ES and i think it works great... I haven't tried it yet in the GS but i always use higher octane in the GS Just try it it won't hurt the engine....it should help it.... Good Luck
Old Aug 8, 2005 | 09:21 PM
koolaidman's Avatar
koolaidman
actually the top engine cleaner i was talking about requires u 2 dissconnect or pull the fuel pump fuse take off the fuel line to the fuel rail. put 3 cap full of the top engine clean into a bottle and then fill the rest of the bottle with fuel. then connect the bottle to fuel line. attach bottle to line and regulate pressure -10 psi to what the regulator is set for. then start car. this in general cleans injectors pistons, pistons walls, egr(if equiped) intake plentum, tb, iac, and valves.
Old Aug 8, 2005 | 10:29 PM
SC400DAVE's Avatar
SC400DAVE
Just go get an E.F.I service done. Simple. Then use good gas. What model do you own?
Old Aug 9, 2005 | 07:23 AM
Lexmex's Avatar
Lexmex
The brand name gasoline in Mexico is pure garbage, I have tried many injector cleaners, but these are my winners:
1) Techron
2) Restore injector cleaner
3) NOS injector cleaner
To be sure, you can get any of these at WalMart or an Autozone.
There are additives you can also use, but not necessary unless you live where I live.
Old Aug 9, 2005 | 08:32 AM
sha4000's Avatar
sha4000
i used the b12 chemtool in my gas plus i used the spray to clean the carbon in the throttle and my idle went from 900 to 1200 on start up this was recommended by several mechanics and it did all that was advertised
Old Aug 9, 2005 | 04:43 PM
xknowonex's Avatar
xknowonex
i personally use Redline
Old Aug 9, 2005 | 04:50 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Chevron with techron fuel injector cleaner!
Old Aug 9, 2005 | 05:57 PM
sha4000's Avatar
sha4000
i used to use the techron and while it was good it didnt compare to the b12
Brabusx2
Sep 11, 2015 02:26 AM
Lukas99GS
Maintenance
17
Nov 1, 2014 09:41 AM
robertog11
Sep 14, 2014 07:08 AM
GX470GT
May 18, 2011 01:12 PM
Indyblonde
RX - 1st Gen (1999-2003)
15
Dec 13, 2008 07:18 AM
