Running Rich and Lean
Old Jun 28, 2005 | 10:30 AM
GoldieLex's Avatar
GoldieLex
Default Running Rich and Lean(code 25 and 26) Help
What are the first things I should do when my car is throwing code 25 and 26? I have seen some threads on this, but i wanted to address the first things i should do to trouble shoot this problem. thanks guys
Old Jun 28, 2005 | 12:55 PM
meZoom!'s Avatar
meZoom!
Super Moderator
maybe you could tell us verbatim what "the book" says about those codes? The DTC book usually have a distinct way of describing the codes and possible causes. If it's a rich/lean problem like your title says perhaps start by looking at your o2's.
Old Jun 28, 2005 | 01:36 PM
GoldieLex's Avatar
GoldieLex
code 25= lean code 26=rich
Old Jun 28, 2005 | 04:05 PM
VVT-i's Avatar
VVT-i
You got a 1992 SC400, check your O2 sensors.
Old Jun 28, 2005 | 06:13 PM
GoldieLex's Avatar
GoldieLex
should i just buy new ones? I am not quite sure how to check them. what other things can cause these codes? Is it probable that it is the o2's?
Old Jun 28, 2005 | 06:37 PM
VVT-i's Avatar
VVT-i
You can take it to the dealer and let them do the " O2 RPM check" by using the scan tool and they can see the wave form on the scan tool. A new O2 may cost you around $200.00 each, plus labor.
Please search for another thread that related to " O2 sensor" in the " Search ".
Old Jul 1, 2005 | 11:19 AM
GoldieLex's Avatar
GoldieLex
Anyone else here ever throw a code 25 or 26 (running rich and lean)? and how was it fixed? thanks guys
Old Dec 15, 2005 | 05:45 AM
silcos's Avatar
silcos
Default lean rich condition,25 and 26 check engine codes
This was for ls400, 1992, 178,000 miles.
I replaced o2 sensors, no luck.
Did a tune up, caps,rotors, spark plugs. Rich condition fixed -I guess new plugs helped that, but lean condition remained. Changed fuel pressure regulator (part# 23280-50010---$103.43 from irontoad.com) and all codes clear now.
chetknox
Oct 29, 2018 09:04 PM
STORMINORM
Aug 17, 2014 12:19 PM
pslack
Maintenance
Feb 1, 2013 02:42 PM
broda805
Mar 13, 2011 03:25 PM
jacobking
Maintenance
Dec 20, 2003 09:38 PM
