!!! Transmission Fluid Question !!!
Old May 9, 2005 | 10:34 AM
DJKLEX's Avatar
DJKLEX
Default !!! Transmission Fluid Question !!!
I bought my 99 GS300 when it had 20K miles and now I have 78K miles. I never changed the transmission fluid in my car . I checked and now it's black. The reason is that, everyone told me to wait until I change the timing belt at 80K miles.
What should I do?
Drain and put new fluid or 100% flush?
Old May 9, 2005 | 11:05 AM
ssultan's Avatar
ssultan
Somebody actually told you to wait till you changed your timing belt/water pump to do a transmission fluid change????!!!!! I just hope to god it isn't your regular mechanic...
Perhaps it's time to take a 'swing' at whoever gave you that advice. I would do a transmission fluid change ASAP...hopefully no serious damage has been done yet. I'm sure the more experience members will be able to provide you with more information regarding possible problems in your case.
Old May 9, 2005 | 01:28 PM
Luxury Motorworks's Avatar
Luxury Motorworks
That was bad advise some one gave you. If you are not experiencing any transmission slipping or check engine light you are probably ok. Your transmission uses TIV transmission fluid it will last a long time but, like any fluid it will get contaminated over time. The most important thing at this point is to completely flush the old fluid out. Don't just do a drain and refill that only replaces 2 quarts of the fluid. Be careful who you get to do the flush. Make sure they use the proper transmission fliud. (TIV) After you do the flush add some BG ATC+ automatic transmission conditioner. The stuff is amazing and will help with any burnt or acidity fluid. If you need help getting the additive let me know and I can get you some. Don't wory you'll be ok.
Old May 9, 2005 | 05:28 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
or you can do a drain and refill 3 times within 500 miles.
Its actually very easy to do, takes about 15mins at home. Just make sure you get the Toyota T-IV Fluid from your local Toyota dealership (cheaper the Lexus dealership).
Old May 10, 2005 | 10:24 AM
DJKLEX's Avatar
DJKLEX
THanks
My AT still runs OK and check engine light never came on. How do I completely flush the AT and how much of thefluid do I need.
Old May 10, 2005 | 02:10 PM
BruteSBC's Avatar
BruteSBC
just drain it and put new fluid in it. thats it. dont take the pan down. 4 quarts of ATF. it will be fine.
Old May 10, 2005 | 03:30 PM
Luxury Motorworks
The easiest thing to do is find a reputable place with a transmission flush machine. They work really nice. Have them replace all your old fluid with new TIV. You do not have to pull the pan down. You can also remove the transmission cooler line that goes to the radiator. Put the cooler line in a pan. The best thing to do would be to find a "T" fiting with a valve between the radiator and the cooler drain hose so you can open and close the valve as you wish. Put a funnel in where the transmission dipstick goes. Start the engine and the transmission pump will pump the old fluid into the pan. (be careful for it will make a mess from the pressure). While the old fluid is coming out you fill the funnel with new fluid. It is best to use two people so you can monitor the fluid coming out while you are putting new fluid in. After you use about 8 quarts the transmission fluid should start to look a little better. Add the BG ATC+ and you should be fine. Then I recommend doing a drain and refill every 15,000 miles so you will not have to deal with this again.
(food for thought) Statistically it costs 3.3 times more money to fix your car than it does to maintain it.
Old May 10, 2005 | 07:59 PM
TLW's Avatar
TLW
lol that is too true
well said
Old May 11, 2005 | 05:14 AM
Lexusfreak's Avatar
Lexusfreak
Cool
What should I do?
I'd do a 100% flush personally........consider using Amsoil synthetic ATF (compatable with both Dexron III & Toyota type IV). Hopefully there is no serious damage to the tranny. Clean the filter mesh screen & install a new tranny pan gasket also as a preventitive measure.
You need to take it to a place that has the tranny flushing machine. I suggest the 100% change now, and just a drain & fill every 2 years or 30k miles thereafter.
Old May 14, 2005 | 10:48 AM
ILOVEGIRLS's Avatar
ILOVEGIRLS
how much is the additive? i always have a hard time reading the dip stick. whats the best way?
Old May 14, 2005 | 01:10 PM
Lexusfreak's Avatar
Lexusfreak
Cool
How much is what additive? I wouldn't suggest adding any kind of additive to the tranny, just fresh fluid.
Old May 16, 2005 | 10:03 AM
Luxury Motorworks
The additive is $12.00.
Start your engine and let it warm up. Run it through all the gears and drive the car if you feel you have close to the right amount of fluid. The dipstick is kinda hard to read. Leave the car running in park on a flat surface. Pull the dipstick out, wipe it off, and stick it all the way in again. When you pull it back out lay it on it's side so the fluid will not run up or down on the dipstick. If it is hard to read place white paper under the dipstick and you should be able to see where the fluid is on the dipstick much easier.
Old May 17, 2005 | 12:16 PM
ted920's Avatar
ted920
Do you think I can take my Lexus GS 3 to a Toyota dealership for them to do the Tranny Fluid Flush?
My GS has 43,000 miles and still has original tranny fluid.
Btw, how much do you think it;'' cost for a complete tranny fluid flush with the Toyota Type IV fluid?
Thanks,
Ted
Old May 17, 2005 | 12:38 PM
TLW's Avatar
TLW
when you say clean the filter mesh screen ..what are you exactly doing
and where are you getting a tranny gasket from
ive had my pan down ..there is no gasket .....i kick my self for not taking pics
Old May 17, 2005 | 02:39 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
yup, they use that sealer stuff... no gasket anymore.
