Check Engine Code 1150
Old Nov 20, 2004 | 03:31 PM
PeteO's Avatar
PeteO
Default Check Engine Code 1150
I am new to this code stuff but am fairly handy fixing cars. I have a CEL that comes and goes on its own, every couple of days. The car is a 2000 RX300. 86000 miles. I took it by Autozone and they got a P1150 code that said "lack of HO2S21 switch adaptive fuel at limit". I nosed around the forum and found the Lexus Code Retrieval post and it said "Air/Fuel Ratio Sensor Circuit Range/ Performance Malfunction (Bank 2 Sensor 1)".
I take it this is a 02 sensor. Where is it located and where can I get a good cheap one? I will greatly appreciate any help you can give.
PeteO
Vero Beach, Fl.
Old Nov 20, 2004 | 04:23 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Bank 2 is in the front of the car... and Sensor 1 is the sensor in the manifold, right before the cat. As far where to get one cheap... that i cant help you with.
And it actually is an Air/Fuel sensor, not an O2 sensor. They are different. You have 2 Air/Fuel sensors in your car, one before each cat. And you have 1 O2 sensor, after the two forwards cats.
Old Nov 20, 2004 | 08:23 PM
steviej's Avatar
steviej
try online at www.sparkplugs.com
your Denso Air/Fuel sensor is $221.32.
steviej
Old Nov 21, 2004 | 02:09 AM
PeteO's Avatar
PeteO
RT & Stevie,
Thanks for the info. It's enough to get me started. Just discovered this forum the other day and boy is it a world of info and help.
Pete
2ks
RX - 1st Gen (1999-2003)
78
Jun 13, 2020 08:21 PM
Bluv
Nov 9, 2015 01:28 PM
00Lexus
Jul 31, 2013 11:05 AM
perduefred
May 2, 2011 03:32 PM
palaka
Sep 3, 2007 06:58 PM
