Spark plug replacement recommendation on all Lexus models.
Old Mar 14, 2008 | 10:47 AM
  #46
Da CaVeman's Avatar
Da CaVeman
Exclamation Rear sparkplugs....how to get them out
First off, hello all! I've been on this forum for the past few weeks educating myself about my 98 es300...I've had it for about 2 years now. (Bought it used from my uncle) I finally registered and now I am ready to share some knowledge hahaha. Anywho, I just recently changed my plugs and as most of you know, the front 3 are easy as cake but the back 3 are nearly impossible without the right tools. I dont know if its been posted yet but the following is the tool combination that I used to take the rear ones out with very little effort.
1. of course you will need the basic rachet, spark plug socket, and 3 " extension just as you would use for the front 3 plugs
2. Next, (this is key) attach a universal joint attachment. This will allow you to angle the extension piece (# 3) and rachet up and out above the entire engine.
http://buy1.snapon.com/catalog/item....re&dir=catalog
3. attach a 6" or 10" extension. Whichever makes you feel more adequite ;-)
4. Finally, attach the rachet and you should be able to unscrew the plug with plenty of clearance and you are home free!
You'll have to be a bit nimble with the fingers to get each piece down to the plugs and attach everything and then removing them. There is very little room. It might be handy if you keep one of those magnet sticks around just in case you drop something in the engine bay.
My lack of microsoft paint skills held me back from drawing a little diagram but hopefully someone will understand this and explain it a bit better.
Hopefully this helps!
Goodluck!
Old May 17, 2008 | 04:55 AM
  #47
ChuckD_20's Avatar
ChuckD_20
how do you remove the intake on a 93 SC300
Old Nov 20, 2008 | 09:40 PM
  #48
evanis300's Avatar
evanis300
Default Spark plugs.
According to this post, my is300 needs replacement of spark plugs @ 120,000 miles. Recently went to a mechanic and they told me they needs replacement. This sounds like a bunch of BS to me. I have not even noticed any miss fire on my motor, wouldn't it be obvious performance wise if I needed new plugs?
Old Nov 21, 2008 | 06:35 AM
  #49
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
It's not impossible for plugs to wear out before they are scheduled to. A number of things can cause that such as bad gas, a failure in the PCV system, bad oxygen or air flow sensors, etc.
What I do question is why does your car need them? First off, in the automotive repair industry, "need" is a bad word. According to MAP (http://www.motorist.org/index.cfm) guidelines, things are either suggested or required, depending on what's wrong with them. Spark Plugs can fall under all kinds of different MAP codes, so I'll run through them real quick...
Required codes - A: Does not perform it's intended purpose (pretty simple, a spark plug failing to fire, etc) B: Does not meet design specification (gap is too big, crack in insulator, etc) C: Part is Missing (obvious)
Suggested Codes: 1: Close to end of useful life (you can't really use this one on spark plugs, as there is no wear indicator or easily identified way to tell how old they are or when they are going to fail) 2: Address customer need (basically, it wouldn't be a bad idea, if you'd like to do it) 3: Manufacturer Recommendation (it's scheduled maintenance time) or 4: Based on informed technician experience (this would be used if you saw a valve cover gasket leaking - you would "require" the valve cover gasket based on MAP code A above, and use MAP code 4 for the PCV valve - it's well known that a blocked or partially blocked PCV valve is notorious for causing leaky gaskets)
Anyways, depending on why they told you that the spark plugs "needed" replacement, I could either agree or disagree... Is your check engine light on? If so, is there a misfire code stored in the computer? If this is true, even though you may not feel a misfire, it is quite possible that there is and it will get worse (with a possibility of harming other things like O2 sensors and catalytic converters).
If they are suggesting spark plug replacement based on mileage and no other criteria, then maybe they are just wrong about the maintenance interval... I have to look up every car because every single car is different... some cars still have 30k spark plug changes, others 60, some 90, some 100, some 105, and some 120...
Spark plugs are definitely one of those things that you want to be proactive with, but only to an extent...
Old Feb 9, 2009 | 02:34 PM
  #50
LEXUSF's Avatar
LEXUSF
Originally Posted by VVT-i
Here is the list and recommendation for the spark plug replacement that list in the Owner's Manual and Repair Manual for Lexus models and years.
ES300:
1990-1998 60,000 miles
1999 90,000 miles
2000 to date 120,000 miles
IS300:
2001 to date 120,000 miles
RX300:
1999 to date 90,000 miles
SC400/430
1992-1998 60,000 miles
1999 90,000 miles
GS300/SC300
1993-2000 60,000 miles
GS400/430
1998 60,000 miles
1999 90,000 miles
LS400/430
1999 90,000 miles
LX470
1998 60,000 miles
1999 90,000 miles
LX450
1996-1997 30,000 miles
I hope this will help some of you to make the decision on your services. We have a lot of discussion about this issue before and how the Lexus dealer charge you for certain services. This is just a guide line that Lexus recommended in the owner's manual, not madatory or anything.
is-f ??? what does it use?
Old Mar 29, 2009 | 01:42 PM
  #51
Sc4004me's Avatar
Sc4004me
gserep, when you do your timing belt and water pump, please pay special attention on line up the timing mark before you loose the timing belt tensioner. The manaul will tell you to line it up at TDC and then move it up for another 30 degrees( I'm not sure). This is very important step.
Does this apply to late 1UZ-FE engines only? I have 92 sc400 and the 1991 factory service manual states "crank on 0"and cams lined up on the marks.Nothing mentions addtional 30 or 50 degrees anywhere.Im confused and don't know which it is..
Please let me know,just did the T-Belt ,everything on 0 tdc and im nervous to start it ,before im 100% sure of this...
Old Nov 24, 2010 | 11:36 AM
  #52
shawn011's Avatar
shawn011
Default I need spark plug wire routing on 98 es300
I changed the plugs and messed up the wire somebody please help
Old Feb 27, 2011 | 08:13 AM
  #53
ken386's Avatar
ken386
IS300 middle spark plugs.. equals pain in the *** change up !!! will be replaceing soon.. will post pics for peoples refernece
Old May 5, 2011 | 12:54 AM
  #54
b3njam1n's Avatar
b3njam1n
Cool i wont have to change till 120,000 miles...long way to go still !
Old Jul 12, 2011 | 03:00 PM
  #55
NjLexSc400's Avatar
NjLexSc400
what added power or drivability do expensive plugs give you?
Old Jul 12, 2011 | 03:08 PM
  #56
mitsuguy's Avatar
mitsuguy
You may hard pressed to find someone who has actually done extensive testing to compare the two, but some will claim a little extra hp and fuel mileage by using the higher end plugs...
IMO, there is virtually no difference, all other factors remaining constant - spark plug gap, protrusion, etc...
The one main difference is service life of spark plugs varies greatly... Copper plugs usually 15-30k miles, platinum plugs 60k miles, iridium plugs 100-120k miles... give or take, that seems to be the recommendations...
If you don't mind changing plugs every year or two, I actually prefer the copper plugs - I can gap them as needed, no need to worry about damaging them on installation or if I pull them out to check and clean them, etc...
If you are paying someone to do the labor, its probably cheaper to stick with the platinum or iridium plugs, as the added expense of the plugs will be cheaper than paying someone to install them more often...
SC400slide
Oct 31, 2021 04:41 AM
Kharizma
Oct 3, 2011 08:34 PM
SILVA1
Jul 26, 2007 02:37 PM
HarrierAWD
RX - 1st Gen (1999-2003)
Mar 28, 2004 07:08 AM
ToyotaLexus
18
May 10, 2002 05:05 PM
