Recall: Any updates?
I know there are other threads that have been started about this, and most have been told engine replacement. My recall notice stated the "fix" was not yet known and that additional info would be available at a later date.
What says you?
no issues or problems otherwise.
What says you?
I was originally told by my service advisor it would take six months to get a new engine from Japan.
Anyone on here get a new engine? Did the LX drive the same or anyone notice any differences with the new engine?
https://static.nhtsa.gov/odi/rcl/202...4V381-8828.pdf
Transfer original components from original engine to new engine
a. Transfer the following components from the OLD engine assembly to the NEW engine
assembly.
• Engine Wiring Harness
• Generator
• A/C Compressor
• Drive Belt Tensioner
• Drive Belts
• Misc. hoses/brackets
That's it for old stuff.
Pretty much everywhere that oil has gone to will be replaced.
The engine assembly is this part, 04004-23170 Engine, Assy LX (Not returnable).
The whole thing arrives in a crate, unhook the seized one, hook the new one and register. no major mess with internal engine components.
assembly.
• Generator
• A/C Compressor
• Drive Belts
I have a 2024 model with a 7/24 build. Not part of the second recall. I'm assuming there will eventually be a 3rd recall that covers mine. But who knows? I don't think we know if or when the root cause has been fixed.
I would love to know what the actual failure rate is for these V35a engines across all model years. I don't think this is public information unfortunately.
The bigger issue is that Lexus does not really understand the issue. Logically speaking, how can residual debris in an engine cause failure 40K+ miles later after multiple oil changes? How can the residue left in the engine occur at multiple manufacturing facilities? The debris is long gone by this point, or if stuck in the oil galleys, would have cratered the engine very early in the life of the engine. Just does not make sense. I have seen pictures of the damaged crank bearings......it is catastrophic. It did not occur over time. If Lexus truely thought the cause was engine debris during manufacturing and the problem has been solved, they would say the "fix" is a new engine....period. I can't blame Lexus for the lack of transparency as they have a business to run. I also have confidence in the company to do the right thing. At this point it seems they don't know what the right thing is. We will see.
It’s painfully obvious that this issue is a design flaw, NOT “machining debris in the engine from the manufacturing process.” Your reasons (which I have also said in the past) are 100% correct and valid. Debris in the engine will be washed around/out quickly when the engine is new, and will be caught by the oil filter and/or be found in the oil pan as metal shavings/sparkly debris. Slag doesn’t just lie in wait in the cracks and crannies of an engine for years or tens of thousands of miles and then suddenly appear and cause main bearing failure, while sparing the top end of the engine any issues (cam lobes, lifters, etc.).
The other thing that people don’t fully see, perhaps, is that the majority of these failures are happening while the engine is under load — for Tundras, that means towing, four-wheeling or other times when the engine is in heavy use. For LX600s, the failures I’ve seen (especially over at IH8MUD) have tended to be when driving at highway speeds.
The fact that they are rattling their legal sabers to suppress information and have info taken down off the internet, is telling.
In my opinion, it’s only a matter of time until the two YouTube videos from “I Do Cars” and “The Car Care Guru” — both HIGHLY knowledgeable and reputable experts on engines — on the V35 engine, will be forced to be taken down. Toyota/Lexus can’t help but see these types of expose videos as very damaging. But….the cat’s already out of the bag. It’s gonna be hard for Toyota/Lexus to put this genie back in its’ bottle….
I am not convinced they fixed the problem or even know what the problem is.
In a perfect world, I would wait a couple years and see if the problems have been resolved. Such as gamble at a high price point.
i hope the problem is fixed, but am skeptical.
Potential Number of Units Affected: 4,374
Problem Description:
Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain 2025-2026 Lexus LX600
vehicles. In the event of transmission solenoid failure, the communication may fail between the
transmission electronic control unit (ECU) and the engine ECU, resulting in transmission damage.
Consequence:
A damaged transmission can cause a loss of drive power, increasing the risk of a crash. In addition, a
damaged transmission can leak transmission fluid, increasing the risk of a fire.
Remedy:
Dealers will update the transmission ECU software, free of charge. Owner notification letters are
expected to be mailed April 25, 2026. Owners may contact Toyota's customer service at 1-800-331-
4331. Toyota's number for this recall is 26LA01.
