LX - 4th Gen (2022-present) Posts related to the LX600 belong in this forum
Hardwire Dash Cam Install with Instructions
Old Oct 27, 2024 | 04:06 PM
Mikerx80's Avatar
Mikerx80
Default Hardwire Dash Cam Install with Instructions
Take off the plastic cover under the front glove compartment. There are 3 tabs you need to push. You can also twist the courtesy light to fully dislocate the cover from the attached wire.
Under there, you will see a fuse box. These are what you will tap into for both on/off (p/outlet) and parking mode (Dome) functions. I used a ROVE connector with type C connection to add an old cam (Coxpal) I had from my old LX570. I prefer the dual cams as it eases the install not having to install a separate camera with another tap, etc.
You will then take off the side cover of the dash and pull the plastic cover near the right of the passenger footwell. There is where you will find a tap for ground and can start hiding and pulling the wire over to the pillar airbag and up to where the rear view mirror is located.
Here it is installed.
BinhN
TX Models (2024-present)
43
Jan 31, 2026 03:37 PM
Antibody33
CT 200h Model (2011-2017)
Oct 23, 2023 03:43 AM
Torii
NX - 1st Gen (2015-2021)
Apr 23, 2017 09:07 AM
WolfyLS460
Hybrid Technology
Dec 27, 2016 02:33 PM
1blkls430
Dec 31, 2007 08:52 AM
