Lexus TX 350 Dash Cam Install
1st Gear
Has anyone tried to install a dash cam through the rearview mirror? We attempted to do so but the cover is on pretty tight and we don't want to break it. We tried looking a tutorials from other cars ( the 2023 GX and RX) but the cover for this one seems different.
I installed one using the fuse at the lower corner of the driver footrest
I tapped into one of the usb power fuse, and route the cable through the weather rubber seal to the the spot next to the rear view mirror.
Does anyone had to remove the A pillar trim to route the wire? I heard from someone that I should not route the wire over the airbag.
This is my first time installing a dash cam and I am afraid that I may damage something in the process.
You don’t need to remove the A trim, just pull the rubber seal and squeeze the wire in the gap, when you reach the top of the ATrim , squeeze the wire in with very light force. After that everything is easy.
Ehan85 (01-05-24)
I installed the OEM Lexus Dashcam. Installation was very easy. I was going to connect to via the digital mirror utilizing a wire harness, but I found an open connector above the interior lights.
The following 6 users liked this post by RybakT:
coolbrazz (02-20-24),
Derek305T (05-14-24),
Ehan85 (01-22-24),
MiamiTX350 (04-08-24),
Rancherman (03-29-24),
and 1 others liked this post.
how do you like that dashcam? I have never had one in any vehicle I have owned and the TX I hope to take delivery of later this week has this one installed already at the dealer....
It's good, there are better video quality dashcams on the market like BlackVue or VIOFO (have the A129 installed in my GS350) but I wanted the seamless integration and factory look and finish. That's why I went with the OEM dashcam.
coming from a german brand where you can configure and order away this is a lot different...
gotcha. I didn't have a choice because the car has one installed. so that is what I am working with. not a lot of luxury trim cars coming into dealers in MA so I settled on a few things including color...
The following 2 users liked this post by RybakT:
MooneyPilot (03-12-24)
totally get it.
2nd dashcam for the TX
Interesting. I actually didnt notice the outlet there but it is a good suggestion.
Any chance you know where the fuse box in the TX is? Side note, is that the OEM cargo liner?
