LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
LX570 wont start
Old Oct 16, 2022 | 08:00 AM
apigo200x's Avatar
apigo200x
5th Gear
Default LX570 wont start
hello
i have 2009 LX570 with engine dead so i have buy used engine from tundra and installed to my car everything is ok but engine crank but don’t start !!!!
fuel pump ok
spark ok
cylinder compression ok
everything is ok on this engine ( i have video for this engine on the tundra before removal and it ran well)
thx
File Type: wmv
Old Oct 16, 2022 | 11:51 AM
05ls430518's Avatar
05ls430518
What about the anti theft stuff? Are you sure the harness between the two motors is the same?
Old Oct 16, 2022 | 12:14 PM
apigo200x's Avatar
apigo200x
5th Gear
hello
no anti theft immo is ok
is the same same engine 3UR-FE with same harness
Old Oct 16, 2022 | 04:14 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
If you have fuel, spark & compression the engine should run. You are missing something.
Old Oct 16, 2022 | 04:20 PM
apigo200x's Avatar
apigo200x
5th Gear
yes maybe but what?
Crankshaft Trigger Ring on TUNDRA is the same on LX570 ?
Old Oct 17, 2022 | 03:23 AM
05ls430518's Avatar
05ls430518
Is the green and red anti theft lights blinking? Also are you 100% positive the harness is the same and it's not wired differently. The harness can plug in but does it have the same wires in the same spot etc. Something could be pinned differently.
Old Oct 17, 2022 | 05:50 AM
apigo200x's Avatar
apigo200x
5th Gear
is the original harness from old engine
and anti theft light flash when ignition off
with ignition on anti theft light go off
Old Oct 18, 2022 | 04:30 PM
apigo200x's Avatar
apigo200x
5th Gear
hello
ecm can dead without give any error code?
because i think my problem is the ecm
Musta75
Apr 9, 2021 12:10 AM
aalmos
Oct 27, 2020 05:32 AM
LexusOz
Nov 7, 2017 12:36 AM
