LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
How to I close/fix this gap?
Old Sep 13, 2022 | 06:39 PM
ljCharlie's Avatar
ljCharlie
Default How to I close/fix this gap?
I have a 2014 LX 570 and I couldn't figure out how to close this gap. I pushed in and it seems to close but then two to three minutes later, it opens up again. Any suggestion? This is a used vehicle when I purchased so the previous owner must have done something.
Old Sep 14, 2022 | 02:07 PM
Ratchey's Avatar
Ratchey
Chances are the clip behind it is bent and not going into the correct slot. Pull it out if you can and realign the clip if it isn't already broken off.
Old Sep 15, 2022 | 07:24 AM
z32's Avatar
z32
Agree with the OP. you'll need to take the panel out, inspect what's going on, adjust if possible and re-insert.
Old Sep 16, 2022 | 08:28 AM
ljCharlie's Avatar
ljCharlie
I opened up this far and it does not look like anything is broken. If I shut it tight, it'll slowly opens up again in about 1 minute or 2. Everything where else on this panel/cover is tight except this spot opens up the gap showing in the initial post.
Old Sep 16, 2022 | 10:06 AM
ljCharlie's Avatar
ljCharlie
By the way, what is the plastic cover call?
Old Sep 16, 2022 | 08:47 PM
bigguppy's Avatar
bigguppy
Bend the plastic up and that should help hold it in place. If not buy some double side tape and do one layover on the side of the clip. Force it in and that should work. It shouldn’t take much force.
Old Sep 18, 2022 | 10:04 PM
z32's Avatar
z32
Looks like those plastic clips r worn... put a few construction / painters' tape 1-2 wraps and reinsert.
Old Sep 20, 2022 | 08:42 AM
ljCharlie's Avatar
ljCharlie
At the moment I used Gorilla Removable Mounting Putty and it seems to hold for now. I'll see how long it last. Thank you for the responses, much appreciated!
CRL RFR
GX - 1st Gen (2003-2009)
Jul 3, 2011 11:00 AM
CVsIS250
Sep 13, 2006 05:01 AM
