LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
LX570 Suspension
Old Jan 20, 2020 | 02:41 AM
SL%%'s Avatar
SL%%
Question LX570 Suspension
Question friends, is the LX570 equipped with:
1.) air suspension?
2.) Is this different from hydraulic suspension?
3.) if air suspension, how is it so far to those who are equipped with air suspension in terms of reliability?
thanks
Old Jan 20, 2020 | 04:47 AM
DarKnight's Avatar
DarKnight
I'm fairly new to the LX, not necessarily Lexus, but I'm sure they mostly, if not all, use a hydraulic suspension.
Old Jan 20, 2020 | 01:25 PM
Ratchey's Avatar
Ratchey
It is Hydraulic, not air. There have been very few failures of the system that I am aware of other than the shocks needing replaced at some point due to leaking. Usually well over 100K miles. It is a robust and intelligent system that works well for what it is supposed to do.
Old Jan 20, 2020 | 02:43 PM
hankinid's Avatar
hankinid
1.) air suspension?
thanks
We haven't done our homework...have we?
The AHC (Automatic Height Control) system is very reliable, as it should be in a Toyota product. All you need to worry about is changing the AHC fluid every 60K miles. That takes all of 30 minutes, and fluid is available at your Toyota or Lexus dealer. Shocks are always a wear and tear item so expect replacement, the same as you would for air assisted or no assist suspension.
Air suspension, as used on Land Rover and other vehicles, is generally a nightmare in reliability.
Old Jan 20, 2020 | 10:00 PM
SL%%'s Avatar
SL%%
hahahaha thaks friend.. don't really understand the terminology at times and gets confused
sounds good for me...
Old Jan 20, 2020 | 11:55 PM
lexusrus's Avatar
lexusrus
On our previous gen 2000 LX470, no problems with the hydraulic AHC system when we traded it in back in 2013 with some 280K+ miles on the odo. We adhered to the routine maintenance schedule and no problems.
Old Jan 21, 2020 | 04:02 PM
Ftcgsf's Avatar
Ftcgsf
I was wondering if the AHC actually raises the chasis and or frame to improve on the ground clearance and approach angle, breakover angle, and departure angle as well as the ground clearance or if it only raises the LX body ? In other words does the AHC actually improve ground clearance and approach and departure angles for off roading.
Old Jan 21, 2020 | 04:36 PM
Ratchey's Avatar
Ratchey
The AHC pushes fluid into the shocks to raise the chassis and drains the fluid to lower it. It is designed specifically to give you better ground clearance when off-roading (It will automatically raise it to hi when in 4low and it detects bumpy terrain) as well as lower it when driving at speed for better aerodynamics and lower it when parking to provide easier ingress-egress.
Old Jan 21, 2020 | 04:48 PM
Ftcgsf's Avatar
Ftcgsf
Thank you ! So what you are saying is the 2 inches you gain when the AHC is engaged actually gives you 2 more inches of ground clearance, and better approach and departure angles ? Not just lowering and raising the " shell/body" of the LX.
Old Jan 21, 2020 | 04:55 PM
Ratchey's Avatar
Ratchey
It probably closer to 4 inches total (maybe more) between the lowest and highest setting. And no, it is not adjusting the body/shell of the vehicle. There would be no advantage to that. You can actually raise the vehicle 1.25" just by adjusting the AHC sensors (and adding spacers to reset the pressure) for a full time lift and still have your adjustability.
(keep in mind that if for some weird reason it did just raise the body/shell, you would probably have better approach/departure angles, but not better break-over or ground clearance - but that is not how this system works)
Old Jan 21, 2020 | 05:21 PM
hankinid's Avatar
hankinid
1.) air suspension?
thanks
Air
Much different
N/A for Toyota...talk w/ those who drive Rover or MBA.
I'd suggest checking the 200 series FAQ section on ih8mud.com.
Asked and answered I'd say.
See above, as well as check the link above.
Shaq32
16
Nov 5, 2019 07:35 PM
Sailcail
Apr 17, 2019 10:56 AM
FatherTo1
Jul 22, 2017 08:37 AM
prwdmd
Aug 22, 2015 06:02 PM
Endless49
Suspension and Brakes
Jun 27, 2013 04:37 PM
