Modified taillights w/ sequential Turn signal
Tools that I used to cut the lights open
cut this plastic glue to separate the light with the side cover and remove 2 screws
Make your cut line
Start your cut, b patient do nicely
remove this screw
and this
dont lost your rubber washer
start pry open the back cover, do slowly and firm, dont force it, some spot need deeper cut
peel back the weather strip
push down the rubber.
I continue Later for the outer light
https://www.clublexus.com/forums/lx-...installed.html
cut the plastic glue and remove 2 screws
Start make your line
start your cut...again nice and easy....
remove this screw
and this
this
and last one...
peel back the weather strip and push down the rubber
remove the connector from the bracket
you can start to pry open...again firm and slowly
I'll continue the electronic part tomorrow....
1st of all, watch your LED orientation, make sure is matched with these pictures
these what I used to make connections and parts
join all the positive side of the LEDs together..
solder LED drivers, the positive toward the positive side of LED
add cable for power (about 6"-8").....and put all the board a side....we work on the outer light now.
Remove this screw and lift the board
remove this screw
and this
remove the tape
cut the pink and blue wire
one higher then the other
Heat shrink together
Pull the turn signal back, nicely...at this point you better wear latex glove...you dont want finger print all over you taillight.
remove all blue and yellow tape
remove this connector (carefully)
and this..
and this..
remove those 2 screws
and you can remove the back cover.
pull out all those LEDs board...
now you have to cut some of copper line...scrape some of the paint..
add some LED driver (pay attention to the polarity)
solder this way
After done all three, you can put the board back to where is belong and also put back the back cover and screws
put back all the connector and cut this wire
and this
joint the pink withe grey cable
and heat shrink, now do same with the back cable
and heat shrink...
extend all the wire (red, black, grey and blue)
I drilled the rubber gasket to take out the 4 cable
Used JST connector to make it neat
I used Ghozt Lightning for the sequential turn, just google "Ghozt Lightning"....need to tested before closing the taillights...from Ghozt lightning module, use ch1 for the inner LED (the closest one to the "L" logo, and ch19 for the outer led.
adjust power supply to 12V....you should see the leds sequential...if everything work good, we can start closing.....
This what I used to close the taillights back....
Put back all the screws and make sure the cut off align,, used clamps to help line up
after that I used Black silicon to make it water tight....
the rest of the light it's pretty much the same process.....Good luck guys.. if you have any questions just DM me..
When I get home I'll review the pictures and your info.
I have questions for you and I hope you can help me.
