Replacing Multi-media Interface ECU - Help
Also, it is not recognizing my 5th Gen, old school iPod (which I still cherish for its amazing audio quality due to its Wolfson DAC). This Technical Service Bulletin addresses the iPod issue. http://www.revbase.com/BBBMotor/TSb/...dPdf?id=167576
So, replacing the old multi-media interface ECU with a new version will fix the iPod 5th gen problems I am experiencing. And, I suspect that this updated part may also address the weird behavior my audio system exhibits a couple of times each year.
Apparently, Lexus updated the ECU back at the time of the TSB (new revision of the PN), the PN (then and now) is 861A0-77010. It is located underneath the front passenger seat.
Has anyone changed this part before? Any tips on removing the old / installing the new ECU? Does the entire passenger seat need to be removed to change this part?
I would greatly appreciate any help!!
