LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Clunking noise from front end
Old Dec 10, 2017 | 09:34 PM
z32's Avatar
z32
Default Clunking noise from front end
Not sure if I'm doing it wrong. When vehicle (MY15) suspension is dropped to low, turned steering about 80% right / left, then gently move forward / backward, there is a clunking noise possibly from the front that sounded like axle noise...just 1 cluck noise though. But when raised to 'Normal' or 'High' that noise no longer present. Am I doing something wrong (meaning am I not supposed to set the suspension to 'low' while turning?)
Also suspension set at 'Normal' height, from a stand still then shift to 'D' or 'R', sounded like differential / axle / drive shaft getting engaged (just one click). Is that also normal?
Old Dec 11, 2017 | 09:51 AM
REDHORSE's Avatar
REDHORSE
My 15 does not make such a noise.
Old Dec 13, 2017 | 06:25 AM
z32's Avatar
z32
I'll probably have to get my car in to dealer to have that checked out.
But w/ regards to the noise that sounds like axles / gear engaging (when shifting into 'D' / 'R' w/ foot on brake), that's normal?
Old Dec 13, 2017 | 09:18 AM
hankinid's Avatar
hankinid
I'd start with the simplest / cheapest solution first...
When was the last time the driveshafts were greased...that means all 4 u-joints and both slip joints??
Old Dec 13, 2017 | 09:32 AM
REDHORSE's Avatar
REDHORSE
No grinding when shifting on mine.
Old Dec 13, 2017 | 10:09 PM
z32's Avatar
z32
My truck only has 25k miles. All services done at Lexus dealership. I would assume at least drive shaft should have been lubed each time (every 5k?) But not sure.Will the driveshaft supposed to be lubed during each service anyways?
Old Dec 14, 2017 | 12:38 PM
Max707's Avatar
Max707
yeah it’s in the service manual every oil filter change lube and retork driveshaft they never do it until you start hearing noises and complain and then it’s hard to get them to do it even though they’re supposed to do it so you’re gonna have to go in and tell him that there is a zert for every driveshaft And coupling i believe there’s like six of them. If they tell you they never service them and that they don’t need to be on a 200 then asked to talk to the service manager because your service advisor is a dumbass
Old Dec 15, 2017 | 09:59 AM
hankinid's Avatar
hankinid
The 5K / 6 month interval is correct.
Boston35
Suspension and Brakes
Nov 7, 2012 11:02 AM
Phresh2010
Jul 7, 2012 08:56 PM
Valet Park
Suspension
Aug 20, 2006 10:05 PM
l7in6k
Dec 22, 2002 10:15 PM
