LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Where did my sound go?
Old 10-11-17, 11:55 AM
vj70
vj70's Avatar
Default Where did my sound go?
I changed the battery and the sound was gone. I checked all the fuses and they're good(I have an electronics background), but still can't get sound. The mode changes, but when I change the volume the numbers that show the volume going up or down are no longer there. I read the posts that are here about the amp replacement and I'm hoping I don't have to do that, if I do i'm tricking it out old school. If I have too change it out, will I also lose my a/c controls?
Old 10-11-17, 12:00 PM
ggebhardt
ggebhardt's Avatar
Have you tried hold down the volume button to reboot the radio/nav system?
Old 10-11-17, 12:03 PM
vj70
vj70's Avatar
Yeah, I held it for a minute and nothing happened. Just powered on and then off, I tried it twice.
Old 10-11-17, 12:06 PM
vj70
vj70's Avatar
It's ironic you're in Jax and I actually scheduled an appointment there today to bring my truck for a service check because of this and the locking differential light has tourette's....
Old 10-11-17, 02:55 PM
vj70
vj70's Avatar
So, I'm an impatient old Marine that used to do car stereo installations back throughout the 90's and figured that it was going to e like a certain amp from back then that had fuses in the inside, well it didn't. I've taken the radio out the out and apart and no matter what I do I can't get the volume to even show up on the radio and since I've tested all the speakers I know they work, I just can't check the output from the head unit because it won't respond. going back in......
Old 10-12-17, 01:59 AM
ggebhardt
ggebhardt's Avatar
Hope you get it sorted out. Sounds like a dealer thing, hope no too expensive.
Old 10-12-17, 02:06 AM
vj70
vj70's Avatar
Yeah it’s one of those things that won’t let me sleep. I’ve narrowed it down to the head unit not the amp.
Old 10-13-17, 05:32 AM
ggebhardt
ggebhardt's Avatar
If so it will be expensive to replace, even if you can find a used one.
Old 10-13-17, 10:51 AM
hankinid
hankinid's Avatar
The diff lock light issue can be exercised by regularly driving the truck for a bit while in low range...not an uncommon issue.
hth
Old 10-13-17, 12:49 PM
vj70
vj70's Avatar
Awesome, I will give it a shot. I’m in an area that requires a little 4x4 action anyway!!
Old 10-13-17, 01:23 PM
hankinid
hankinid's Avatar
Wink
If you're not a user on ih8mud.com, you may want to check it out. A quick search on the 200 series forum there got me this thread...LOTS of reading but having had the same yellow light turned on when it should have been off, I've followed the thread almost since it started. https://forum.ih8mud.com/threads/dif...riving.853294/
I learned a lot more about the TC lock button than from my owners manual...e.g., if you're in sand it helps a bunch to unlock the TC.
Steve
Old 10-13-17, 02:21 PM
vj70
vj70's Avatar
Sweet, Thanks!! Mostly street riding, but just bought a new place on 10.5 acres, so I'll be dragging a trailer around a lot more than I used to.
blaiset
GX - 1st Gen (2004-2009)
08-24-19 11:48 PM
Theavlexv6
08-27-18 06:25 PM
Jerdog
09-25-17 05:47 PM
15951
11-20-09 04:15 PM
elsmooth
09-23-09 01:40 AM
Quick Reply: Where did my sound go?
