LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Replace rear hatch struts
Old Feb 9, 2020 | 08:16 AM
mrhenry123's Avatar
mrhenry123
i ordered new struts. the tops have the triangular mounting plate attached.
how to i unbolt the the tops from the upper liftgate. they are recessed and look to back into metal ?
Old Feb 16, 2020 | 06:19 AM
mrhenry123's Avatar
mrhenry123
any comments on those bolts?
Old Feb 16, 2020 | 10:21 AM
caesosa's Avatar
caesosa
They are a PIA to get out. You have to remove the seal around it to make sure you get full contact with your socket. It’s a few screws and a pop off to remove that piece. The bolts on the struts are VERY tight if they are still factory and you can strip them if you don’t have full contact.
Old Feb 16, 2020 | 01:09 PM
Ratchey's Avatar
Ratchey
hi guys -
i ordered some new rear struts from liftsupportdepot.
how to you remove the top triangular piece that is bolted to the hatch ? it looks like the bolts are recessed and cannot unscrew all the way.
You have to remove the rubber trim that is over them. It's kind of a pain and there is a pointless clip that you will most likely break.
You can try pushing it out of the way, but it is easier to remove a few of the screws holding it in.
I already answered this above. Nothing has changed in the method needed to remove them since the last time you asked.
simplecar
RX - 1st Gen (1999-2003)
Jan 4, 2020 05:15 PM
bonasa
Jan 4, 2015 07:41 AM
radhead25
Dec 28, 2005 03:28 PM
eddied106
Jun 8, 2003 10:33 PM
