LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Another LX 570 Tire Question
Old Aug 4, 2024 | 07:02 AM
psychodoc's Avatar
psychodoc
Default Another LX 570 18" Tire Options Question
I have read the tire threads but can't find all the info I need so here goes & TYIA
I'm likely purchasing a 2015 LX570 next week that has aftermarket 18" rims but LOUD AF mud tires that I will be replacing ASAP w/new 18s
Can anyone tell me some/most/all the possible 18" tire sizes that will fit (& the ~2-3 best sizes / best for the vehicle) ?
I've seen everything from 285/60/18 to 275/75/18 & others / Would like to search/find the best deal & prices seem to be all over the place (based on size, etc)
Any/all help is appreciated... If there's a link w/all the info please post it below...
Old Aug 4, 2024 | 01:29 PM
Misteracng's Avatar
Misteracng
285/60 18 I believe is the OEM size for 18inch wheels. This is the landcruiser OEM size because lx570 did not actually come with 18inch wheels stock. For quiet highway tires looks like Michelin defender ms2 and Yokohama geolander HT G056 are good and similar. I think most would prefer Michelin, I have the Yokohama in 21 inch and it is good. The Yokohama is significantly cheaper on tire rack.
Old Aug 10, 2024 | 12:55 PM
psychodoc's Avatar
psychodoc
Anyone veered away from 285/60/18s ? My '15 LX570 has 275/65/18s, but I'm tire shopping b/c they're loud mud tires & I hate them
Found some new take offs for <1/2 price but they're 265/70/18s & a little concerned about performance/fit
Old Aug 10, 2024 | 01:16 PM
Misteracng's Avatar
Misteracng
Tire size calculator shows the s65-70 would be more diameter, 1 inch more diameter so there might be an issue. If you want nice quiet road tires, there will e plenty of options in standard 285/60 size
Old Aug 24, 2024 | 01:49 PM
psychodoc's Avatar
psychodoc
Ended up going back w/Toyo 275/65-R18s b/c I found a deal (& they have really improved the ride & noise). Those damn Kenda R/T tires that were on it when I bought it are for sale (cheap) if anyone is near 32408...
Old Aug 26, 2024 | 06:15 AM
LEEAUTOVN's Avatar
LEEAUTOVN
4th Gear
Original tires 265/65R18 will fit 7.5J rims, see your actual wheel if it is 8.5 or 9J, in my opinion it will be more suitable with 285/60R18 9J, or 8.5J with 275/65
Old Aug 26, 2024 | 06:44 AM
Misteracng's Avatar
Misteracng
The LX 570 originally had 20 or 21 inch wheels. The Landcruisee did come with 18x8 inch wheels. The stock size is 285/60 18. If you seek a quiet ride go with Michelin defender ltx ms2. Or the Yokohama geolander HT g056 if you want a bit cheaper. I have driven both and they are similar, quiet comfortable
Old Aug 26, 2024 | 12:10 PM
psychodoc's Avatar
psychodoc
Like I said... went w/Toyo HT 275/65-18s & they'e fine & the price was right...
Much better ride...
Old Aug 26, 2024 | 12:17 PM
Misteracng's Avatar
Misteracng
Forgot to add, with aftermarket wheels they will likely not be the same offset so you maybe need to take that into account
Old Aug 26, 2024 | 12:26 PM
psychodoc's Avatar
psychodoc
Are you referring to effect on speedometer & other related gauges or tire rub ?
These have plenty of room all around & I think the difference in diameter is negligible
Old Aug 26, 2024 | 01:15 PM
Misteracng's Avatar
Misteracng
I think the Speedo error is no problem as long as you get it close, most aftermarket wheels have much less offset, maybe it might tire choice if you go larger diameter. Stock is I think +60, aftermarket are like 30 or less so it swings the tire more into the wheel well with turning. It should be much issue with stock sizes or close to that
Old Aug 26, 2024 | 01:46 PM
psychodoc's Avatar
psychodoc
Yea, I'm so close to the stock on the LC 18s it's not an issue...
Old Aug 26, 2024 | 04:08 PM
Ratchey's Avatar
Ratchey
My snow tires are 265/70/18 and they look rediculous. Way too small and the speedo is off by about 7 to 8mph.
275/65/18 will make your speedo accurate to within 1mph.
Here is the info you seek on tire sizes https://forum.ih8mud.com/threads/200...tabase.818686/
Old Aug 28, 2024 | 09:18 AM
psychodoc's Avatar
psychodoc
Thanks... Ended up finding 2) '<1k mi. New-ish Take Off' Toyo 275/65-18s for $150 (& a newish Michelin spare for $40), so only had to buy 2 'new' Toyos & the dealer got everything swapped for me & I saved ~$500... Much better ride & looks fine... I think the 265/70/18s would have looked ridiculous as you stated...
rclfast
NX - 1st Gen (2015-2021)
22
Oct 16, 2021 03:49 PM
MadDane
Suspension and Brakes
Mar 18, 2014 05:34 PM
jesod
Wheels, Tires & Brakes Forum
12
May 16, 2007 01:52 PM
hbsc300
Jun 7, 2005 07:47 PM
