LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Adding subwoofers?
Old Jun 3, 2006 | 07:38 AM
aedgington's Avatar
aedgington
Default Adding subwoofers?
Well, I ended up w/ a nice enclosure w/ 2 JL Audio 12" subs in it. I was wondering if I could stick this in the LX w/out too much work or if my wife's car is going to get it... 02 LX w/ ML.
Old Jun 3, 2006 | 08:41 AM
cliffud's Avatar
cliffud
Former Vendor
if you both want subs - make 2 sub boxes and put a jl sub into each one. mdf from home depot is cheap.
amp wise, i'd count on giving each sub 500 watts rms and you'll both have a rocking system. i just bought some mdf to make a box in my gf's rav 4... c'mon - YOU CAN DO IT!
Old Jun 3, 2006 | 02:54 PM
20blks's Avatar
20blks
What are you doing with the existing speaker? Mine is blown and I need another one.
Old Jun 3, 2006 | 09:41 PM
trukn1's Avatar
trukn1
NELOC Mod
I got 2 12" MTX's in the trunk of a 92 LS 400, with an adaptor to get the factory Premium Pioneer system to work with this. I know for a fact that you can put that in an LX. I chose to get mine installed. Took about 4 hours, but install is very clean (thanks Circuit City) and absoluty no wires are showing except at the install points (battery, capacitator, amp, box). If you didn't hear me coming, you would never know I had in car. Cmon, you can do it. Don't be scared. We got your back!!!!
Old Jun 4, 2006 | 05:15 AM
aedgington's Avatar
aedgington
So you think I need a 2nd amp, or run it off the factory Levinson amp?
Old Jun 4, 2006 | 08:53 AM
trukn1's Avatar
trukn1
NELOC Mod
I just had them leave the factory amp to power the door speakers as normal, but also had them install an amp to power those big boys in the trunk. If you going for boom, that factory amp will not put out nearly enough power to run those subs, so yes I would suggest install of additional amp for subs. Without it the ML amp will have to try to spread all of its power to all components in the car and with the power ratings on those subs, it will not be anywhere close enough to get effectiveness from them. Better to have more power and turn down if necessary then to be underpowered from the start.
Old Jun 13, 2006 | 02:02 AM
20blks's Avatar
20blks
What size amp did you use?
Old Jun 13, 2006 | 03:58 AM
aedgington's Avatar
aedgington
I'm going to use a Pioneer GM-5200T, specs are:
125w x 2 rms @ 4 ohms, 250w x2 peak @ 4 ohms
190w x 2 rms @ 2 ohms,380w x 2 peak @ 2 ohms
380w x 1 rms @ 4 ohms,760w x 1 peak @ 4 ohms
I'll bridge it & should be good to go.
Old Jun 13, 2006 | 06:57 PM
20blks's Avatar
20blks
Also, what size speaker fits back there?
Old Jun 14, 2006 | 01:55 PM
ArmyJoe's Avatar
ArmyJoe
Anyone have some pics of clean LX installs? I am trying t think how it would work... with the seats and stuff. Where have they been put? Plenty of space for some mobile electronics in there though huh? A single clean JLW3 or W6 maybe 8,10 or 12 might suprise you...
SixSeven
May 20, 2019 05:48 AM
shabbir1
Dec 25, 2013 02:42 PM
mikobangz
Sep 10, 2013 01:49 PM
GS4_Fiend
13
Mar 4, 2010 08:11 PM
