'01 LS430 Puddle Light Removal
Aug 1, 2007 | 02:13 PM
Anybody done this before? I need to replace the bulb. I see that there are some screws behind the mirror (I can see three...guessing there ares four), but I can only get the two outermost ones out. Moving the mirror to the top/bottom/left/right only gives me a very minimal amount of space, barely enough to get my screwdriver in, so I don't think I can take the mirror off like
this member . Is there some trick to it?
Thanks in advance!
Aug 1, 2007 | 04:20 PM
i believe that the mirrors do pop out (carefully), if im correct . . . . .
Aug 1, 2007 | 06:00 PM
Aug 10, 2007 | 11:31 PM
Aug 11, 2007 | 12:04 AM
Inside there are 4 clips, it just pops off on the back(behind the mirror), 2 on the bottom 2 on the top (inside) from there its easy....
Aug 11, 2007 | 10:16 AM
So, do I just lift the mirror off? There's not enough space for my fingers to go all the way inside, even with the mirror all the way up or down.
Aug 12, 2007 | 12:44 AM
The actual mirror does not come off, you just gotta pry it open, its a two peice...but just take it slow...and try not to break the inside clips
Aug 12, 2007 | 10:03 AM
Like this (I know that is an IS...are my LS430 mirrors similar?):
Quote:
Originally Posted by
CaThaFeR
Aug 12, 2007 | 11:27 AM
Aug 13, 2007 | 08:35 AM
Should I lift it off from the outside or the inside (clip side or non-clip side)?
Sorry for asking all of these questions...I really don't want to break my mirrors and have to send my car to the dealer...
Aug 13, 2007 | 10:55 AM
I would slowly pry each side slowly until you get enough to pop it off...
Aug 13, 2007 | 11:04 AM
Thanks a bunch! I will give it a try tonight.
Aug 13, 2007 | 01:30 PM
Aug 13, 2007 | 01:38 PM
Just get a really really flat thin screw driver...unless you have something else that will work, let me know how it goes too.
Aug 23, 2007 | 05:27 PM
I couldn't even get it to budge...
Oh well.
BTC89LS400
Feb 22, 2017 10:43 PM
ffred
Feb 27, 2011 04:34 PM
LEXuriouss
Jan 22, 2007 12:46 AM
messysc
Jul 31, 2001 09:38 PM
