So I decided to lower the Led lights and found that there was only an option to lift the lights up and down but not widen which was an option on my GS. There is a aluminum block that stops you from being able to do this. Wondering if anyone else has this issue as I suspect maybe only the adaptive light users have this option.
What is the option to lower the LEDs?
Dealer told me there was no adjustment. I, too, would like to lower the lights just a bit; others are flashing their high beams at me.
You are talking headlights, right?
yep headlights, I circled where but you would need a long screw driver as there are gears at the end of it the raise and lower the beam.
