Jerking when releasing / engaging brakes
Old Oct 22, 2018 | 07:01 PM
franklexus's Avatar
franklexus
Default [SOLVED] Jerking when releasing / engaging brakes
I've been driving my LS for around 9 months now. I noticed the car jerks / lurches quite abruptly forward when I take my foot off the brakes slowly, and also when I brake slowly (it doesn't seem to engage properly). I don't remember experiencing this in my early days with the car. Wondering if anyone has the same experience? Thanks!
Problem solved: There is a TSB for this issue which reprograms the ECM: https://www.clublexus.com/forums/ls-...ift-delay.html
Old Oct 22, 2018 | 10:40 PM
shinonclub's Avatar
shinonclub
Which version of the LS 500 do you have? My LS500 regular version does not seem to have any problems with the break system.
Old Oct 23, 2018 | 06:35 AM
seanspeng's Avatar
seanspeng
I feel the same.
Old Oct 23, 2018 | 08:06 AM
franklexus's Avatar
franklexus
Originally Posted by seanspeng
I feel the same.
Thanks for the replies! I have the regular LS 500. I will bring it in to have them take a look at it.
Old Oct 23, 2018 | 09:18 AM
dsc07's Avatar
dsc07
I don't think what you're feeling is a break issue, it is a transmission issue. Gears 1-4 are not configured correctly. The lurching is most pronounced during gradual deceleration/acceleration.
Old Oct 24, 2018 | 01:02 AM
AustinHusk's Avatar
AustinHusk
Sounds like the same issue I have with my 2015 F Sport!
Old Oct 27, 2018 | 09:34 PM
franklexus's Avatar
franklexus
Originally Posted by dsc07
I don't think what you're feeling is a break issue, it is a transmission engine. Gears 1-4 are not configured correctly. The lurching is most pronounced during gradual deceleration/acceleration.
I've observed it a bit more and you're right! The lurch is very pronounced and definitely un-Lexus like!
Old Nov 2, 2018 | 04:47 PM
seanspeng's Avatar
seanspeng
Just finishing a service, advisor said jerkiness is because inadequate warm up. I asked how many minutes, he said 5-10 minutes warm up.
Old Nov 2, 2018 | 05:37 PM
dsc07's Avatar
dsc07
Horsepucky!
Old Nov 2, 2018 | 05:54 PM
seanspeng's Avatar
seanspeng
Hope others can get some more insights when your maintenance is done. I was like: what? Every time I start my car, I need to wait for five minutes? Not even a grandma will do that!
Old Nov 3, 2018 | 10:03 AM
kghoshal's Avatar
kghoshal
Folks... this may help you. I had to literally get into a "science project" mode to get to the bottom of this issue. You may have caught one of my narratives on this exact topic under a different thread. Since then a fair amount of water has flown under the proverbial bridge in the past 3 weeks. Let me explain the lengths I went to... if it helps some of you fellow afflicted ones.
I received delivery of my LS500 back in Feb (one of the very first lots to arrive in the US). Being relatively cold that time of the year in Dallas, I attributed the "lurching" to cold-starts of the engine. Which turned out to be somewhat true... it'd lurch at EVERY cold start - and that could happen (in the cool season) for anything beyond a 6 hour stop for my car. Annoying at first, it started to become a nuisance after 3 months of driving... as it started to do the same after every gear shift from reverse to drive as well. The dealer - to be fair at that point in time - had not received such complaints from Dallas area owners/drivers of 5LS. They asked me to monitor (and I've been a client of this dealer for 20 years through 6 LSs in a series) the performance and report back, given that they no feedback from corporate Lexus re this issue at that time.
I just couldn't take it any more 3 weeks ago - after having driven for 8 months and approx 3K miles (yes, I tend to put on very few miles on my car). But it was long enough and enough miles for them to run "forensics" on the issue. After the last straw was had by me, I took it to the dealer and had them run all kinds of tests. They kept the car for observation and tests for two days, dedicated the head tech of the dealer, who in turn called upon Lexus corporate head techs.for answers (and YES, he was able to simulate the "lurch"). After two days, the dealership called and informed "unfortunately there is no known solution/fix for this issue". Apparently it is a firmware issue and Tokyo is aware of this (due to numerous inputs from the first-batch of buyers by now). There'll be a wholesale firmware patch on the 2018 5LS models once it's completed.
This is where I deviate from the usual LS story. Given the longevity of my relationship as a client to this dealer, they offered to "buy the car back" and fit me with a new LS. Which I proceeded to do two weeks ago. It's still a 2018 LS500 - but from the second batch of production. And in this case I upgraded from the base model to the model with enhanced package (the one with mark Levinson audio system). As of now, this is car has about 400 miles on it... have not experienced the acute lurch that I did with the previous one (fingers firmly crossed of course... it's only been 2 weeks) - don't know if the "upgraded" car has anything to do with transmission/firmware issues (I thought the upgrade was purely on the cosmetic side of things. However, if this helps any of the fellow afflicted ones... for whatever it's worth :-)
Old Nov 3, 2018 | 12:09 PM
seanspeng's Avatar
seanspeng
Thanks for sharing. Mine is probably also 1st batch as it was released in February. Good to know the corporate acknowledged the issue and hope it's not a difficult fix and they will address it soon.
Old Nov 3, 2018 | 12:22 PM
franklexus's Avatar
franklexus
Thanks to all for sharing, much appreciated! Mine was the 1st batch too (got it in February). I've been driving my car around in Comfort mode ever since I got it. The lurch is more pronounced in that mode (I think the car somehow adapted to my style of driving). When I switched it to Normal mode recently, the lurch is much reduced. So I wonder if it is an issue of the transmission "adapting" incorrectly to the driving style over time... I've not had time to bring it in for the service. Perhaps those with the lurch can try switching to Comfort and see what happens.
Old Nov 3, 2018 | 01:38 PM
kghoshal's Avatar
kghoshal
Many thanks for this tip. Actually hadn't thought of that angle. Am surprised the tech didn't suggest it either - unless they were able to simulate the jerky start-stop in all modes. I waiting to see if my new one start doing the same (currently driving in "comfort" mode).
Old Nov 6, 2018 | 04:01 PM
franklexus's Avatar
franklexus
Problem solved! Please see this thread: https://www.clublexus.com/forums/ls-...ift-delay.html
MrShirls
Mar 12, 2014 12:33 PM
azmd
Dec 12, 2011 02:10 PM
mikemareen
HS 250h Model (2010-2012)
17
Aug 11, 2010 08:23 PM
jc3103
Apr 12, 2008 08:01 AM
kjbro
Jul 29, 2002 11:02 AM
