Water leaking on driver side door
Old Aug 20, 2025 | 05:40 PM
navilexus's Avatar
navilexus
Exclamation Water leaking on driver side door
I have a 2018 LS 500 driver door leaking. Could this be a weatherstripping seal? Today raining I notice wet from the driver side above head area always down and dripping around my left foot floor. Sunroof completely drive inside, could it be weatherstripping seal?
Old Aug 21, 2025 | 01:57 AM
PGA71's Avatar
PGA71
It could be a clogged sunroof drain. Especially if the A-Pillar is wet. If you have the panorama sunroof, I would advise having the dealer clear the drain-lines.
Old Aug 25, 2025 | 11:38 AM
navilexus's Avatar
navilexus
OK went to the dealer. The initial check for the leak is $219.00
It was the Sunroof rubber molding deteriorated and need to be replace.
The cost is $1459.59. Wow!!! that's crazy.
Check the part # 63251-50070 only $68.00
Unbelievable!!!!.
Old Aug 26, 2025 | 06:12 AM
LS500zoom's Avatar
LS500zoom
Curious, is that the fairly thin, fairly soft rubber seal that is in front of the sunroof panel, one you can see from outside top of car and goes from left to right? If yes, is it torn?
Best,
David Zoomzoom
Old Aug 28, 2025 | 03:15 AM
sajack's Avatar
sajack
Something must have damaged the weatherstripping.
I have owned more cars with sunroofs than I can count and never had a leak.
Could it possibly be repaired? A picture would help.
Old Aug 28, 2025 | 07:19 PM
navilexus's Avatar
navilexus
I lost all trust in Lexus Dealership and Lexus certified mechanic. All vehicles with sunroof tent to leak, but the drain suppose to drop the water onto the ground not into the floor. Instead, I got a quote for $1459.59 minus a $219.00 initial check for the leak.
The part itself only $70-$80.
Went to local shop cost me $20 to blow the high pressure air into the drain and it stop leaking into the floor.
Himain
Hybrid Technology
14
May 12, 2025 05:56 PM
LatinLS430
Jan 5, 2024 12:09 PM
Lexus-SSA
RX - 5th Gen (2023-present)
Dec 9, 2023 06:16 PM
TommySC300
SC400 / 300 Classifieds
Aug 10, 2010 12:31 AM
timgs300
Dec 13, 2008 06:35 AM
