2007 LS460L used Nav unit replacement
Old Feb 1, 2023 | 10:15 AM
vegasvip's Avatar
vegasvip
10th Gear
Default 2007 LS460L used Nav unit replacement
It looks like my navigation/climate controls screen went out of my 2007 Lexus Ls460L. At first the screen was going on and off intermittently but now its has completely went blank. Seems like all the ac buttons below it still function okay but nothing on the screen. Not sure if the LCD screen just went bad or unit is bad. I've seen some used Navigation units on Ebay for a couple hundred bucks but just wanted to see if anyone else has had this problem, and if its just a simple swap of a used unit in or if something else needs to be done during the process to make it work.
Any feedback would be awesome Thanks in advance!!
Old Feb 1, 2023 | 12:05 PM
swfla's Avatar
swfla
Many recommend sending your unit in for repair. Buying used is a gamble. United Radio is one company for repairs, do a search for others.
Old Feb 1, 2023 | 12:53 PM
tx170754's Avatar
tx170754
Hi Tech Electronics in California will do it for you, they did it my , now departed, 2007, excellent job !
Old Feb 1, 2023 | 09:42 PM
vegasvip's Avatar
vegasvip
10th Gear
I will call them tomorrow and try to get a quote but the website showing repairs up to $1200, I've seen some used units for around $300-$400. Has anybody ever done a swap with a used unit, is it just plug and play?
Old Feb 2, 2023 | 02:25 AM
ausLX's Avatar
ausLX
You do have buyer protection and can return it if you pay with paypal on ebay, but I still wouldn't buy used unless I saw it working, in person.
Old Feb 2, 2023 | 06:15 AM
swfla's Avatar
swfla
That's true about Ebay. Buying a used part that is know to have higher than normal failure rates is a gamble. A used unit may be older than the current unit and be months away from an issue. The repair shops thoroughly inspect for all issues.
Old Feb 2, 2023 | 06:31 AM
tx170754's Avatar
tx170754
I tried to replace the hard rive on mine with a used one from Ebay and it did not work, then I have sent them the whole unit and they fixed it, I didn't remember exactly but it was something around $650 a while ago....
Old Feb 2, 2023 | 06:51 AM
rick3242's Avatar
rick3242
Another option you may want to consider is this. Probably more then you want to spend but will give much more functionality.
https://www.ebay.com/itm/115394209228
Old Feb 2, 2023 | 08:57 AM
swfla's Avatar
swfla
Have you tried this unit? While these "Chinese" units may be OK for some car models, I've read several reviews about them not working properly on LS and other low production models.
Old Feb 2, 2023 | 09:04 AM
rick3242's Avatar
rick3242
No I have no experience with one. I reviewed the seller reviews and although they have a good review only two appear to be for these units one good and one bad. So yes you may be correct.
Old Feb 26, 2023 | 01:22 PM
vegasvip's Avatar
vegasvip
10th Gear
I finally decided to just buy a used one from Ebay for $380. It was a direct plug and play and now works perfect in case anyone else on this forum was thinking to do the same. Thanks everyone for their input.
Old May 2, 2023 | 03:49 AM
sallensr's Avatar
sallensr
did you get the whole unit. display screen and radio? Thinking about going the same route. Also was it difficult to replace?
Old May 2, 2023 | 06:30 AM
swfla's Avatar
swfla
It's all one unit. There are some Youtube videos about removing center console/faceplates to do it. Not hard but requires some inexpensive clip tools.
NoVaLS
Jan 3, 2023 10:09 AM
NXGuy200
Sep 1, 2017 08:59 AM
drewster12
Sep 27, 2013 06:41 PM
Lexus07470
Nov 27, 2006 04:08 PM
