Bench testing Information Navigation Display screen
Old Dec 4, 2022 | 09:19 AM
NoVaLS's Avatar
NoVaLS
7th Gear
Default Bench testing Information Navigation Display screen
I'd like to purchase a used navigation display screen for my 2007 Lexus LS460. However, before I disassemble my dash to pull my existing screen, I want to learn how to bench test a replacement unit. Specifically, what I mean is: when I receive a replacement navigation display unit, I want to power the unit on my work bench using an external power supply to verify that the replacement unit works before I disassemble my dash to remove the old unit and replace with the new unit. I'm attaching a picture found from the internet of the back of a replacement display unit. My questions are: can anyone educate me about which pins on the back of the unit should be connected to power and ground in order to test the unit on my workbench? What would you recommend as the simplest way to rig up an external power source to the unit.
Many thanks in advance
Old Dec 6, 2022 | 06:51 PM
V8cars's Avatar
V8cars
10th Gear
This is the pinout - https://pinoutguide.com/Car-Stereo-T...1_pinout.shtml
Old Jan 3, 2023 | 07:03 AM
NoVaLS's Avatar
NoVaLS
7th Gear
Default Navigation unit pinouts
Thanks, but you provided the pinouts for the radio...I am looking for the pinouts for the navigation unit, which is physically located above the radio. Anyone know where to find the navigation pinouts>
Old Jan 3, 2023 | 07:13 AM
rick3242's Avatar
rick3242
not sure if this is what you are looking for but I googled it and ......
https://portal-diagnostov.com/en/202...60-2009-model/
Old Jan 3, 2023 | 09:52 AM
trogdor113's Avatar
trogdor113
Terminal 132 is the primary power supply for the display and navigation unit. You'll probably want these pins:
  • 1: Battery, constant 12V+
  • 2: ACC position of ignition, 12V+
  • 3: Ignition on, 12V+
  • 10: Ground
  • 12: Illumination signal, 12V+ when light switch is set to tail or manual on
  • 26: Dimmer signal, 9V+ when lights are on AUTO and the light sensor detects darkness
I'm not sure on the exact nature of signaling for pins 12 and 26; the manual mentions PWM on the illumination circuit on a different terminal. I would guess that the same 12V supplied to one or both of those pins should be enough to test the backlighting for buttons and other controls.
Old Jan 3, 2023 | 10:09 AM
trogdor113's Avatar
trogdor113
Sorry, above may be 2010+ but I'm leaving it here for reference. 2007-2009 likely matches this:
Terminal 59:
  • 5: Illumination, 12V+ when light switch is on
  • 10: Ground
  • 12: Illumination, 12V+ when light switch is on
mnotojr
Jun 21, 2022 11:21 PM
Hilux111
Aug 23, 2020 04:34 PM
NXGuy200
Sep 1, 2017 08:59 AM
longbeach9
Feb 29, 2016 08:53 AM
SrWilliams
Jan 30, 2014 08:21 AM
