Used car.
Old Jan 31, 2023 | 05:00 AM
Ekul61's Avatar
Ekul61
Default Used car.
In the market for a $15000 Lexus. Can I find a LS worth buying. Or is the es a must in said price range.
Any year is fine
Old Jan 31, 2023 | 06:29 AM
swfla's Avatar
swfla
It really depends upon the maintenance, repair history of the car. The powertrains can easily go 300k. How far are you willing to travel? You'll have a larger selection of ES. Also. they are two very different cars. For one, fuel economy is 15 city/25 hwy in the LS.
Old Jan 31, 2023 | 07:59 AM
Ekul61's Avatar
Ekul61
I would travel 200 miles for a 1 owner. Not so sure gas is a issue. Was more concerned that for $15k. A LS might need a lot of work.
Old Jan 31, 2023 | 09:27 AM
R Z's Avatar
R Z
There are LS460's out there in the $15K range. But keep in mind, these cars are going to be at least 13 years old or older. While they're great cars, they're going to need repairs. I took a look around and every one in your price range was either wrecked, or crazy high mileage and 2 or more owners. There may be a unicorn out there if you are in no rush and are willing to have it shipped, but $15K would be the beginning of the costs IMPO. Good luck.
Old Jan 31, 2023 | 09:47 AM
THE_CEO's Avatar
THE_CEO
True... i would try to add a few more thousand and get a 13+ model.
Old Jan 31, 2023 | 11:49 AM
dan25man's Avatar
dan25man
I just paid $14,000 for a 2014 LS 460 AWD with 298,000 miles. Facebook marketplace. You can find them.
Old Jan 31, 2023 | 01:18 PM
XF40FSPORT's Avatar
XF40FSPORT
DANG, that's a lot of miles, which is my subjective opinion. I have a '13 that barely broke 90K miles last week.
OP, if you find one w/in your budget, I would personally look to see when the C arms were replaced. Also if it's air suspension, check to see if there's any records of if/when they were replaced. I recently swapped out both front air struts & paid 20% of your entire car budget, but was well worth the expense, rather than swapping them to coils.
GL!
Old Jan 31, 2023 | 02:10 PM
Dave144239's Avatar
Dave144239
Are they really going for that much? I have a 2011 with 69,442 miles on it. Depending on how our cashflow is when my daughter heads to college, I may sell it later this year to buy something else I have my eye on.
Old Jan 31, 2023 | 03:06 PM
swfla's Avatar
swfla
Gather your maintenance records. that should help get top dollar for your low mileage/desirable car.
Old Feb 1, 2023 | 02:23 AM
bpddaddy's Avatar
bpddaddy
A used car dealer friend of mine is currently selling my 2010 LS SWB with 129k miles. He said I should get $15k. California car and here’s what I’ve done to it. Belt Tensioner - Dayco (89380)
Idler pulley - Dayco (89537)
Serpentine Belt - Bando (6PK2100)
Water Pump - Aisin (WPT187)
Thermostat - Aisin (THT005)
Radiator - Denso (2219223)
Gates Lower radiator hose (23477)
Gates Upper Radiator Hose (23478)
Idler pulley upper- Dayco (89537)
Idler pulley lower - Dayco 89580)
Toyota Super Long Life Coolant - 00272SLLC2 x 3
Toyota Valve Cover gaskets - Right - 11213-38030
Toyota Valve Cover gaskets - Left - 11214-38020
Toyota Spark Plug Gasket (11193-38020) x 8
Toyota Throttle Body Gasket (22271-50050)
NGK Plugs DFH6B-11A
Denso coils
K&N Air Filter 33-2381 x 2
Fuel pump spacer gasket (23224-38010 x 2)
Fuel pump insulator (23915-46011 x 2)
O-Ring (90301-A0029 x 4)
Pulsation damper gasket (23279-74010 x 4)
8 Control Arms
2 sway bars
4 KYB Struts and mounts
Vline2 CarPlay
Lexus new warranty door panels and center console
New Alternator
Michelins (4) 20k miles ago
Valley pan re-sealed
Old Feb 1, 2023 | 02:26 AM
bpddaddy's Avatar
bpddaddy
Forgot to add:
2 Trans fluid drains and one full drain at the dealer, and a brake fluid replacement out of the reservoir
Old Feb 1, 2023 | 04:34 AM
Dave144239's Avatar
Dave144239
I keep everything Each car has a folder with title and maintenance records. I downloaded the service history from Lexus when I bought the car in Dec 2017.
hgupt004
LS - 5th Gen (2018-present)
May 30, 2022 04:35 AM
tradosauru
May 17, 2021 05:33 PM
WNC
53
Jul 19, 2017 09:36 PM
Amphibulus
Jul 18, 2014 03:28 PM
SCRUFFDOGG
May 18, 2006 05:23 PM
