Transmission disengages while driving!
Old Dec 6, 2022 | 01:14 PM
Gerf's Avatar
Gerf
Originally Posted by XF40FSPORT
Off topic, but how does your sub hit now that you dialed in the LC2i?
it's very deep, only elephants can hear it haha.
seriously it sounds really good but it doesn't rattle the body panels,the gains are set very low.
Old Dec 6, 2022 | 05:59 PM
taking it back in RN. He said he waited till fluid was at 46C & filled till it started dripping out of overflow plug.
i went to N back to D & even manual mode. Engine revs, but tach stays around 2,000.
in hindsight, moving forward I’m taking to Lexus or Toyota expert for future jobs like this
Thats too hot, it should be at 95f when you start not at the maximum of the range.
Before it even heats up you should turn the car on, fill it to the point it overflows, then wait for temp. As it heats up past room temperature to spec temp it will automatically overflow to correct level, don't attempt to partially fill some arbitrary amount then wait for temp and fill more.
Drain
Engine off fill to overflow
Engine on fill to overflow
Keep engine on cycle all gears (move quickly)
Keep engine on fill to overflow (move quickly)
Keep engine on wait for temp
At temp wait for fluid stream to subside
Seal overflow
Shut off engine
Key on, command VB replacement relearn
Go drive it hard/however you will normally drive but I suggest at least one 0-130 run so it learns high pressure offsets quickly.
Old Dec 6, 2022 | 07:10 PM
XF40FSPORT's Avatar
XF40FSPORT
Drain
Seal overflow
Shut off engine
Meh, I should’ve hit you up prior to getting this done!
So, since fluid wasn’t at proper temp, I’m assuming the fluid level was too low, causing irregularities in shifting properly?
Old Dec 6, 2022 | 07:48 PM
Correct, too high temp means you underfilled it.
Old Dec 12, 2022 | 11:22 PM
XF40FSPORT's Avatar
XF40FSPORT
It's been about 1 week since I took car back to my Indy, & no more issues!
He got a 2nd opinion, and seems the fluid was under filled.
For anyone wanting to know the correct procedure, see post #17.
Now i'm dealing with chirping noise coming from my FL wheel/brake. It's not the wear indicator, or dirty rotors...SMH!
Old Dec 14, 2022 | 09:14 AM
THE_CEO's Avatar
THE_CEO
When was the last time you got your brakes done?
Old Dec 14, 2022 | 01:06 PM
Try slamming the brakes, if you never really use them they can have strange buildup. This is assuming the calipers are clean and all sliding surfaces are greased and you have all the clips and springs installed correctly.
My03Tundra
Feb 20, 2015 01:27 PM
Amai21
Nov 8, 2013 05:43 AM
09LS460
May 25, 2012 05:24 PM
NevadaKid
Aug 8, 2010 05:41 AM
j stuff
15
Jun 7, 2009 03:52 PM
