A weird one...mysterious clunking but not obvious
Old Oct 15, 2022 | 04:33 PM
  #31
Originally Posted by vb9594
Nice. Thanks lwphat66!
So RockAuto has a Moog replacement for the tie rod at $33. Lexus OEM is $80+. Anyone have any strong objections against Moog?
Yep, I do. Their QC has gone to hell post 2018 sellout and the steering is the most important system in your car. OE only
Old Oct 15, 2022 | 05:21 PM
  #32
Gerf's Avatar
Gerf
You might need the tie rod end but there is no reason applying the brakes would stop the clunking if this is the problem...keep looking.
Old Oct 16, 2022 | 04:40 AM
  #33
lwphat66's Avatar
lwphat66
Pretty much anything connected directly to the spindle can be affected by braking. And the more worn the part (especially excessive play), the more a clunk can become a rattle under the right circumstances. Braking can "lock" certain parts in the position they are in when the brakes are applied and prevent them from moving/shifting. This is one of the reasons it's generally not a good idea to apply the brakes in a high-speed corner (especially at or near the apex), as it may adversely affect suspension/steering (handling overall).
Old Oct 16, 2022 | 05:34 PM
  #34
VanGub's Avatar
VanGub
4th Gear
Check this short vid out- noticed the boot was a little torn, then started prying and when the knuckle end hits its limit, you get a clank. Other side not doing it. I think this may be the cause. Is that the lower control arm? https://vimeo.com/760610301
Wait...I think this is the connector for the steering rack. I assume it shouldn't make this sound- correct me if I'm wrong. Can just that bushing be replaced or am I looking at a whole new rack if this thing is clunking like this? Thanks.
I had similar sounds coming from my LS last spring. Suspected control arms but all was fine. The sound was exactly like you described, sometimes one big clunk, sometimes rattle. I cant remember that if braking affected the sounds.
My mechanic also located the problem to be tie rods. However, as he began to remove the inner rod he spotted that it was indeed steering rack that was clunking and had some loose. I have video of the loose steering rack somewhere I think, if it helps, I can find it.
I hope you have a better luck than me, because new one from local seller was almost 8k in euros. Although I managed to find a good deal for used one.
Old Nov 9, 2022 | 04:33 AM
  #35
vb9594's Avatar
vb9594
To put a bow on this...problem solved, and it was the right front upper control arm. I replaced the right side outer tie rod end (it was clicking when I manipulated it by hand) and really thought I had nailed it, but was disabused of that notion as soon as I left my driveway. It did need to be replaced, though.
So I ended up taking it to Jeff's Lex-Toy in Londonderry, NH (https://www.jeffslextoy.com/). They were SUPERB. They went through the car with a fine tooth comb and even used "Chassis Ears" which place microphones all through the car to listen for noises while driving. They came back to me and gave me the definitive answer of "right front upper control arm." Replacing the control arms on both sides came to around $3,500, using all OEM parts, too. Considering how little trouble this 135k mile car has given me in my 65k miles of ownership, I had no problem spending the money. They also did some additional work while they were in there and didn't charge me for it.
My local Lexus dealer quoted me "$5,500 to $8,000 depending on what we have to do." Hell no.
Thanks to all for your help with this, your input was much appreciated. And to anyone in the MA/NH area, you just can't go wrong with Jeff's LexToy!
Brian
Old Nov 9, 2022 | 05:43 AM
  #36
lwphat66's Avatar
lwphat66
Great to hear you got it all sorted out and updated the thread for us as well. And nice decision to get all 8 control arms replaced. I'm sure you're a happy camper now and enjoying the ride again.
olddog
Suspension and Brakes
37
Feb 15, 2020 04:52 PM
Gs46046
Jul 30, 2018 04:38 AM
jfattibe
Jul 10, 2017 02:58 PM
wallaceb
Apr 16, 2012 12:01 PM
4double0
Oct 19, 2003 09:52 AM
