A little noisy....
Old Sep 28, 2022 | 03:31 PM
Cape600L's Avatar
Cape600L
Default A little noisy....
For the last couple of weeks I heard a rattle in left rear. Found the heat shield above the rear muffler had broken free. Upon inspection I realized that the rumble I have been hearing had something to do with the bad patch job someone had done on my upper half of the muffler. Unbelievable. Not sure what the large numbers you can see on the metal are from, but a rust free eBay replacement fixed the issue. I know rusty mufflers are a thing on these cars. Was a fairly easy fix, fyi.
Old Sep 28, 2022 | 04:49 PM
Anfanger's Avatar
Anfanger
I had the same issue, but, I used a MIG to patch the mufflers.
Old Sep 28, 2022 | 05:35 PM
Gerf's Avatar
Gerf
Looks like they were from an ES haha, the exhaust system is cheap crap...mine are starting to go but it looks like it,s a design flaw because there are small indentations in a pattern on them. I have one that drains condensation after a drive, it's hasn't been drilled though....maybe a weld rivet. My 96 400 had a stainless system and not a leak in 26 yrs.
Old Sep 28, 2022 | 05:40 PM
It's cheapened vs the LS400/430 for sure, my 120k more mile LS430 still doesn't have exhaust rust issues whatsoever
Old Sep 29, 2022 | 12:32 PM
Gerf's Avatar
Gerf
Cape600L, what would you ballpark the weight of that muffler and pipe??
Old Sep 29, 2022 | 02:13 PM
Cape600L's Avatar
Cape600L
Default weight
I would say it is maybe 25LB. I can grab it and put on bath scale and let you know. Very manageable though.
Old Sep 29, 2022 | 02:17 PM
Gerf's Avatar
Gerf
No that's ok, I thought it looked like it would be pretty heavy.
Old Oct 22, 2022 | 02:46 AM
BlazeViper's Avatar
BlazeViper
That seems to be a weak point on these mufflers, mine has a hole in that exact same spot.
Old Oct 23, 2022 | 03:05 AM
sha4000's Avatar
sha4000
Why did it always seem to be the drivers side muffler? I just did this job. I bought an OEM muffler for a total cost of $500 and that's because I went to the dealer to pick it up. There are no aftermarket options besides the Walker muffler which is about $300 without shipping so I just went with OEM.
Old Oct 23, 2022 | 08:26 AM
BlazeViper's Avatar
BlazeViper
I had a hole on the passenger side. Don't wait on this repair or you'll end up like Anfanger with a hole beneath your rear seats.
Old Oct 25, 2022 | 12:16 PM
7milesout's Avatar
7milesout
Those spots in the pictures look like spot welds on the inside holding all the guts together. After years of heat cycles and in areas with road salting, thus corrosion, it's no wonder. Perhaps the LS 400 / 430 just happens to have structure under the car that prevents (as much) crap from getting up on top the mufflers. But if salt and condensation get up there and settle, yeah, it's gonna corrode, quality or not.
Mitleider
May 30, 2022 05:31 PM
abudiman
LX - 3rd Gen (2008-2021)
Sep 1, 2017 10:39 AM
shivt1988
Mar 14, 2011 07:28 PM
Kohinoor
Apr 19, 2005 10:17 AM
krypto
Jun 3, 2002 04:44 AM
